Question about Electrolux Epic 6500 Vacuum
Hi, the vacuum runs ok until you either put the hose in or a bit of obstruction in front of the aspiration hole like with your hand . I have checked the bag,it is new, the filter is also new, there is no clog anywhere.
Thanks for your help.
Serge
  • 1 more comment
  • Captain Tony Dec 09, 2007
    My Electrolux Epic 6500 Vacuum shuts down with a bag check indicator when the hose is attached to the cannister, or if your hand is passed over the hole where the hose is connected. The bag is new and is made by Electrolux and the hose is clear.
  • Anonymous Dec 26, 2007
    same problem exactly the same
  • jhobbs202004 Dec 31, 2007
    shuts off when a new bag is in it and it smells like there is smoke coming out of it also the wire to the main part has disconnected or shorted out but i can see a wire disconneected so could you please replace with a newer model because i have had problems with this one for a long time also the suction is not very good and i have cleaned it out thanks
  • 83 Answers
Well, make sure the hose part is not clogged, this happened to my friends recently and their vacuum was smoking, if you're positive this isn't happening then it might be just the engine call the sellers, try to explain and see if they exchange for a new one or a refund.
Posted on Nov 29, 2007
SOURCE:
How do I unclog my Electrolux epic 6500 sr
take the hose off and clean out
the blockage is probably on the angle section of the vacuum head
Oct 10, 2016 | Electrolux Epic 6500 Vacuum
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
My electrolux Epic won't stay running but it runs when the hose is off.
Check for a clog in the hose or most likely the vacuum valve on top needs removed for cleaning or replacing. Hope that helps!
May 13, 2014 | Electrolux Epic 6500 Vacuum
Cord will not retract on epic 6500 sr
Try tipping it on its end,or nearly so. Then tug gently and release until it retracts. This has worked for me nearly every time I'd tried on various Electrolux vacuums.
If this doesn't work, the vacuum needs to be taken to an authorized Aerus Electrolux store for repairs.
http://www.aerushome.com/storelocator/
Jan 14, 2011 | Electrolux Epic 6500 Vacuum
I have an Electrolux Epic 6500 SR vacuum and the hose end with the handle is separating. Power nozzle losing contact intermittently. Is this piece replaceable or repairable?
It is replaceable. Just take it to the nearest Aerus Electrolux store and the service tech will take care of it for you.
Go to the following site and follow instructions to find the stores nearest you.
Nov 18, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux vacuum epic series 6000 SR and bought it used therefore I dont have a manual. I have had it for about a yr and it worked great..it looked like it should have a filter but I didnt...
1. A manual can be downloaded from:
http://www.aerusvacuums.com/support/manuals/.
The Epic 60006500 is located under "Older Models". Download the Epic 6500 manual
2. Check for clogs in the hose and the power nozzle inlet.
3. Disconnect hose. Turn on vacuum. Does it run? If so, place hand over intake? Did it shut off? If it did, the problem is a worn out or broken component inside the vacuum. Generally a result of using generic "made to fit" Electrolux bags. This is a part that needs to be replaced in an authorized Aerus (Electrolux) shop.
Sep 15, 2010 | Electrolux Epic 6500 Vacuum
Hi I have something stuck in the handle of my Epic 6500 series vacuum cleaner. How do I detach it from the hose? Thanks Marina
take your tool caddy off and after filter insert the hose into the exhaust port turn the vac on the object should come out you may have to place your hand over the handel to build up back pressure a few times if it doesn't come out at first
Aug 02, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500 SR series
Ok i found a solution for my Electrolux Epic 6000 which had the exact same symptoms as you describe. I fixed it by disabling the "bag full sensitivity adjustor" (BFSA for short, for the lack of a better term). For that i opened the case, removed the hose that was preventing me from opening complety the casing, unscrewed the transaparent BFSA mechanism.
Here's the walkthrough:
- Open the case: Open the top part of the vacuum (where the bag is)
- Remove the 2 side rubber by sliding them from the back to the front of the vaccuum
- Remove the "plastic cap" at the end of the vacuum (you can slightly lift the vacuum top part to make it easier)
- Now unplug a small air hose to be able to open the case completely.
- Find the BFSA device and unscrew it.
- Now give your vacuum a try... it worked for me.
Nov 27, 2007 | Electrolux Epic 6500 Vacuum
Vacuums Logo
122 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
