Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
1080i question for PT5598HD
I recently bought this tv off a friend of mine..I just want to know how can I get the best picture 1080i format...
I'm using a Timewarner digital cable hd/.... I was using Monster Component Ultra 1000 cables.. and my hd channels weres awesome...but regular channel were ok I guess ... I just recently switch to S. Video Monster ultra Cable...and I think my picture is a little better...but my question is to get to 1080i what kind of cable do I need for my Digital box and tv.
thanks..
ALwinjc
    Scholar:
  • 170 Answers
The best from what i seen is HDMI, DVI, or comp. in that order.
On my 82" HDTV i use the VGA plug connected to P4 3.5ghz.
everything seems to come to life using a computer and good video card.
Posted on Apr 10, 2008
SOURCE:
What is diferent betwin 1920*1080p and 1920*1080I
Television pictures are a series of still pictures that are presented quickly to give the illusion of continuous movement.
1080p and 1080i indicate how these pictures are formed.
1080p is progressive scan. It is a format that "paints" the picture left to right, top to bottom. On older tube type screens, this would cause the top of the picture to be dimmer than the bottom, as the phosphers would fade before the next picture was painted.
1080i is interlaced scan. This format paints every other line from top to bottom, and then paints the lines it missed before moving to the next picture. This evens out the brightness.
If your TV is capable of 1080p, it is considered to be the best picture (but you probably won't see the difference).
Feb 04, 2011 | Audio Players & Recorders
42' hd tv has stretched picture makes people look fat
you have a few settings to size the picture as best as it can be sized.
format, aspect and size . try setting the TV (remote) format to full, fill or just.TV size to 16x9.
If also using a cable/satelitte remote set it to 16x9 size, stretch format/aspect and 1080i output. then just press the # key on cable remotes or format key on Sat remotes to size it best on each channel.
with 16 formats available, today's TVs are doing their best to keep up.
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 29, 2009 | HP PL4260N 42 in. Plasma HDTV
My TV has lines throughout the whole picture
never had this problem until we switched to hd tv service, changed it from 720p to 1080i and it helped it a little. will let uyou know if I find out how to fix it completely
Jun 30, 2008 | Akai PT5598HD 55" Rear Projection...
Changing resolution settings
Change the resolution through your Cable / Satellite box - Go into the menu. Most of the Akai tv sets do not have an option to change the resolution.
Mar 24, 2008 | Akai PT5598HD 55" Rear Projection...
1080i connection has green hue
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 09, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Hitachi 53SDX89BA HD settings
Problem more than likely with the xbox, as the output stream of data from the game platform is not always consistent...accordianman
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Using Hitachi's 53SDX89BA High-def settings w/ HD-DVD
look at these see if this helps
http://www.hdtvoice.com/voice/showthread.php?t=16973
http://www.hdtvoice.com/voice/showthread.php?t=8721
Most HDTVs cannot properly stretch incoming HD signals, however, if the programme is true HD, you should not much of the image off-screen - most new HDTVs have about 2% overscan and the tickers should be on screen when watched in the appropriate stretch mode.
See:
http://www.hdtvoice.com/voice/showthread.php?t=1044 and
http://www.hdtvoice.com/voice/showthread.php?t=1052
Hitachi 1080i Plasma TV
In the video setting go down to reset. You will only need minor adjustment after a reset.
[email protected]
Nov 09, 2007 | Hitachi Televison & Video
Picture turns off sound is on
Hi Anya, Im sorry to hear of your difficulties but very happy to know im not alone. I have the same exact Sony model and the same exact problem. I wasnt sure if it was my Tv or my upconvert Sansung DVD player. I spoke with Sony assistance..and well..they were of no assistance. They blamed it on my HDMI cable, then the dvd's i was playing, then the dvd player itself. I ruled out all of the above. Mine goes black when i play a dvd in the upconvert format (720p or 1080i) otherwise known as digital..but the analog signal goes through fine. Luckily i am within my 30 days since I bought it, so now that I have seen your posting and am certain its a tv issue, I think i will return it and buy a Samsun tv (a great alternative for same price with only drawback being a glossy screen=not good for bright rooms but amazing color clarity). Sorry I dont have answer for the problem other than your not alone on this one. I have read other Sony users listing similar issues. I hope all goes well with you and wish you the best Matthew
Aug 05, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
257 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
