Question about Tatung Elio Photo JukeBox MP3 Player
Tatung M100 Error
I received a Tatung M100. I loaded the software, updated the firmware, formatted the drive and proceeded to load several .WMA files. When I attempt to play the songs I get a "format error". It finds the song, recognizes it as a WMA but as soon as I hit play I get the error. Any ideas? Thanks, John
  • Anonymous Dec 31, 2007
    Have the same issue. Copied wma files to the M100 and when it sees is wma then try to play get format error. Any ideas?
I don't think it plays wma files
Posted on Feb 08, 2008
How do I solve a 49.2f01 error and what could be the problem?
Error 49.2f01 indicated corrupt Firmware, which are Programming instructions that are stored in a read-only memory unit inside the printer and it can be fixed by downloading and the updating the firmware through the following process:
Updating the firmware
Update the printer firmware by loading the new firmware file from the computer. You can find new
firmware files for your printer at www.hp.com. Click here to download latest firmware and firmware updating utility.
1. Open the HP Printer Utility.
2. In the Configuration Settings list, select Firmware Update.
3. Click Choose, navigate to the firmware file that you want to upload, and then click OK.
4. Click Upload to load the firmware file.
Please refer to PRODUCT USER MANUAL (Page-29) before proceeding.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 09, 2010 | HP LaserJet 4700 Printer
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
I too have a fatal error message on my m-robe m-100
Depending on what the error is, it's probably pretty easy to fix. If it's showing error 004, then it's having a problem loading the firmware from the hard drive. Usually this is from a deleted/corrupt file. To find out what the problem is, do this:
Plug the M:Robe into your computer, then when it says charging battery, push the power button and hold the player up to your ear. If you can hear the hard drive spinning, then it's almost definitely just a software issue. If you don't hear the hard drive spinning, it may have a dead drive. If that's the case, you'll have to send it in to have it fixed or buy a new one. There's usually several cheap ones on ebay that have same software problem, and you can just swap parts, or fix the one you bought.
To fix the software issue:
1. Download the firmware from this page: http://www.olympusamerica.com/cpg_section/software_results.asp?id=1145&os=w
2. Plug in your mp3 player, and turn it on.
3. Run the program you downloaded, and follow the instructions.
If step 3 won't work, it could be a damaged file system. If that's the case, open up your 'My Computer' and find the M:Robe drive, then format it, then do step 3 again. You will have to put all your music back on it.
Dec 04, 2008 | Audio Players & Recorders
Device is operating slowly, reset...
Make sure the device is fully charged. Make sure the songs are in the correct format - Mp3 is best; iTunes/AAC will not work; check the bit rate of the songs to make sure they are at acceptable levels.
Also, make sure you are using the Media Manager to convert files. Formatting the player, in this case, might have been a bad idea, b/c it is possible that it erased key system files - I do not see where Sony has the original firmware/software for this particular product on their website, so it is going to be difficult to reload it if that is the case.
Here is some general info: I have seen quite a few threads in which the stated problem is that the Mp3 or Digital Audio Player will not load the songs; will appear to load the songs but will not actually play them in theMp3 player once disconnected from computer; will skip the songs on the player, or show only “0:00” for file length; songs “disappear” all of a sudden (although this particular problem can be caused for many reasons not covered in this article); your store-bought/burned/ripped CD’s will not load into your Mp3 player; or get the error message “File Format Not Supported.”
All of these problems occur because the user is trying to download a song format that the player does not recognize. Every music file is in a certain format. The most common music file formats are Mp3, WMA, AAC (iTunes), WAV, RA, etc.  In addition, every file format type is in a certain bitrate, size, etc.  By far the most common issue is that the music file contains a license or copyright (especially with WMA or AAC file formats).  Each Mp3 player only recognizes a certain number of these formats. Every Mp3 Player is different. You will have to check your Mp3 player’s product specifications (specs) or user’s manual to find out which formats your particular Mp3 player recognizes. When you try to download or sync the wrong file format, you will get one of the errors that I mentioned above.   If you want to know what file type you have, then you must find the location of the individual music file on your computer, right click the title of the song, and select the option “Properties” from the menu.
Mp3 player product documentation is not straightforward.  If a player supports only non-protected WMA files, it will merely say that it supports WMA – it will not tell which type of WMA it supports.  A player that supports DRM-protected WMA’s will usually indicate such on the box (usually with a Windows Plays For Sure logo – which is actually an ironic misnomer).  DRM stands for Digital Rights Management, and it is a type of licensing system for WMA files.  It is used extensively by mp3 player music services such as Bearshare, LeapFrog, Napster, and others.  Not all DRM licenses are created equal – there are licenses with “play rights,” burn rights,” and “transfer rights.”  Play rights mean that you can only play the song on your PC – it will play fine on your computer, but it will not play in your mp3 player even though it appears to transfer.  Burn rights mean that the song can be burned to CD.  Transfer rights mean that the song can be transferred onto an mp3 player that supports DRM-protected files.  Then, there are unlimited licenses and limited licenses.  Limited licenses only allow you to play a song for a certain length of time. You would have to pay extra to continue using the song after that trial period is over – the time length ranges from a few days to several months or longer.
-Tha Mp3 Doctor
Sep 04, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Reformatting songs/mp3 player
The Sandisk site says that your dad's device should play .wav, .mp3 and .wma files. Has the player EVER worked? I got a C250 for my wife as a Christmas present and my computer recognized but refused to communicate with it UNTIL I DOWNLOADED AND INSTALLED THE FIRMWARE UPDATE. The player was a paperweight until then. It turned on and played the demo files pre-loaded on it, but I couldn't transfer a single file into it. Just a thought. Here's the link:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
good luck.
groove_guy
Jan 01, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
I lost my cd with the software for my RCA LYRA MP3 - RD2010
What kind of system you are using? if its windows XP you shouldnt need a cd XP will recongise it. If its windows 98 you can download the drivers and firm at the rca site (link down a few lines) When RCA first came out with the Lyra series the only way to get music onto the device was by using musicmatch jukebox that would convert your mp3 file to mpy before downloading it to the device. But now RCA has come out with a new firm ware update for these mp3 players that improved the players playback quality plus enabled it to use .WMA files. so first go to RCA support http://support.rcaaudiovideo.com/select.aspx?u=downloads and find your player and download the firmware and drivers (if needed) upgrade and install to your player its very easy and instructions are at the same site. You can now convert your music to .wma or use the free Real player that will convert mp3 to wma at the kbps that you request before loading it on. If your music is all ready in wma format you can use windows media player to send the files to your player. One last thing the .wma files that you put on your Lyra player need to be at least 128kbps or higher enhanced playback quality of wma files (160 kbps to 256 kbps).
Nov 21, 2007 | RCA Lyra RD1080 MP3 Player
Yepo digital audio player
hi i can not transfer files to my yepo mp3 it says my comp dosnt support it i have windows vista loaded the manual says i must convert ACT to WAV format could you please tell me how to
thanks
Nov 09, 2007 | Audio Players & Recorders
Operation system error help fixing please please please :(
I mate I saw a reply to a thread on a forum regarding the Elio Photo Jukebox TPJ-1022. I have the same problem as you could you email the software/firmware on how to recover this item.
Thanks
marshy@douza.co.uk
Dec 26, 2006 | Tatung Elio Photo JukeBox MP3 Player
Cannot turn on
You can reset your Lyra player at any time by depressing and continually holding the power button for a minimum of 10 seconds. Upon releasing of the power button, the unit should reset. If it does not, we recommend that you try again by depressing and holding the power button for up to 20 seconds. Constant pressure is required to depress the button for this duration. Second, download the latest firmware for your player. As for the unit freezing I figured out that it has to do with WMA files. try to re-coded your WMA's to MP3. I think it just has to do with the firmware not liking WMA very much. Use MP3 format only and I think you will be fine.
Jan 13, 2006 | RCA RD2826 MP3 Player
Tatung Elio Photo JukeBox MP3 Player Logo
150 people viewed this question
Top Tatung Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tatung Audio Player and Recorder Expert? Answer questions, earn points and help others
