SOURCE: Rope on mower won't pull.
due to the ethanol and additives in todays fuel it can also be your carborator. one of the intakes may be clogged and all gummed up.
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
SOURCE: Put mower in reverse, turned it off and mower
There are safety interlocks on zero turn mowers. These prevent starting unless you have:
1. the handles in 'neutral' position
2. the brake on
3. the mower engagement (PTO) switch off
4. yourself in the seat.
Chances are one of these conditions hasn't been met. Since you were reversing when it happened, perhaps you haven't got the handles back to neutral position?
SOURCE: Why is my troy-bilt mustang
it could need a oil change if it as some age to it could need a new ring set or a new overhaul and it my need a new plug ...
SOURCE: my troy bilt mustang XP is billowing white smoke
check your belts, the drive belt is off or broken, it runs to the back on above the deck belt. Good Luck Tim
