Question about Kodak EasyShare Z650 Digital Camera
Camera will not turn on
I have tried new batteries and the power will still not turn on. I have only had the camera for about 1 year.
  • 1 more comment
  • Anonymous Dec 14, 2007
    Z650 boots up, sound is played then shuts off. tried numerous new pairs or batteries, zoom wont go in either when shutting off just hard shut off
  • burgess420 May 08, 2008
    My camera was working fine the other day. I noticed the batteries were getting low so I changed them out. When I went to use it a couple day's later it would not turn on. Nothing happened. I put other batteries in and still no power.
  • dennypig May 23, 2008
I have a kodak easyshareZ712 IS it is less than 2months old and it shuts off as soon as you turn it on. it comes on for about 1 second and shuts off. i have bought new batteries and it doesn't help
Posted on Mar 06, 2008
MY CANON CAMERA 2000 PS turns on & then off immediately
Possible Solutions.
1. Charge the battery
2. If still not turning on, try using a little rubbing alcohol and wiping the battery terminal(s) on the battery and the battery terminals in the camera. Use a QTip and allow to completely dry before recharging the battery or inserting it into the camera.
2. Replace the battery with new one.
3. On/Off switch may be defective on camera. Charger may be defective. Wire connecting power from charger to wall socket may be improperly connected or loose.
Aug 28, 2016 | Canon Cameras
My brand new samsung s760 camera wont turn on
Charge for 1 hour.
Pull battery's and see if they have power.
If Power is good Make sure they are in correctly
If Dead Replace battery's. ,
The only other thing it Might be, You said the Camera was New, But if the battery's hold a charge the Battery Door might have lost it's Contacts and the battery's won't work without it, It may have been returned to the store before you got it..
Nov 09, 2013 | Samsung S760 Digital Camera
Opens then closes
I suggest you try a new battery, most camera batteries are good for 1 to 3 years.
Mar 27, 2012 | Casio EXILIM EX-Z1000 Digital Camera
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
I have brand new lithium batteries installed & when i turn camera on, it immediately shuts off. camera is only 1 year old
I have the same problem... cleaning the contacts does not work. I'm using NiMH 2450 mAmp batteries, brand new, and I get a low battery indicator immediately. Camera shuts off unexpectedly. A short search online indicates that HUNDREDS of people are having the same problem. Kodak help not very helpful. I'm ready to buy something else!
Dec 11, 2009 | Kodak EasyShare Z712 Digital Camera
Camera Kodak C713 does not turn on..even on trying new batteries..It is 1 year old..
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 30, 2009 | Kodak EasyShare C713 Digital Camera
Our cannon powershot g9 camera is 1 year old. It will not turn on
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Jun 27, 2009 | Canon Cameras
Cameras - No respond?
Try replacing the batteries.That's what my camera did when it just needed a battery replacement.
Jun 05, 2008 | Samsung Digimax S730 Digital Camera
No power with new batteries
needs reload battery settings into the camera, contact fuji services
Feb 08, 2008 | Fuji FinePix A600 Digital Camera
Camera Not Turning On
New Battery. It relys on battery power no mains power like a lappie. And batteries need to be worked. Leave ' em and they die
Jul 03, 2007 | Kodak EasyShare V550 Digital Camera
Kodak EasyShare Z650 Digital Camera Logo
102 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
