Question about Liebherr Premium CTP 3153 Top Freezer Refrigerator
The refrigerators accumulate ice
The back sides of the refrigerators cabinet (Liebherr primium) maintain at 37 degrees F accumulate ice most of the time.
Food products that are in contact with the back sides are getting frosted and deteriorate.
  • Anonymous Mar 16, 2014
    ice biuld up back of Refrigerators side
  • 29 Answers
The fridge distrubutes cold by air movement. A overstuffed fridge can have trouble. There is a fan that blows a controlled amount of freezer air over to the food side, altho when this goes you usually have frozen freezer and food too warm. Make sure the air is allowed to move.
Posted on Jan 28, 2008
Refrigerator
The self defrost mechanism is not working. The evaporator is getting blocked with ice, an insulator, and that affects freezer as well as refrig temps. When you unplug unit the ice melts and it will work till the ice block returns.
Sep 07, 2016 | Refrigerators
Ice tray became disconnected. How do you put it back
There is a release button on the side usually. You ae to push it in to realign try.
Oct 11, 2013 | Liebherr CS-1660 30" Freestanding Cabinet...
We have plenty of water and pressure coming to the refrigerator from the house, but when we try the in-door water dispenser, the water comes out at a slow trickle. Ice is not making. We installed a new...
whirlpool has had frozen waterline issues whats temp in refrigerator and freezer make sure refrigerator no colder that 37 degrees and freezer th 6 degrees
Jan 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Liebherr KBES 3650 - too warm in main fridge compartment. Hi the main fridge compartment of this larder fridge warmer the it should be (milk does not taste as cold as it should). The temp...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Liebherr KBES3650 Stainless Steel...
Ice build up inside refrigerator Liebherr K3150
may be you have a bad temperature sensor or bad control board.
Mar 01, 2010 | Liebherr K3150 Refrigerator
I have an admiral model HMG 67184 side by side and I can't figure out why my freezer section still works but doesn't get cold enough to make ice cubes and the other side doesn't work at all. I do have...
1. Get the Food out of the Ref and Freezer. Unplug the power cord from the wall.
2. The cooling coil is in the back wall of the freezer side. Working from inside the Freezer.
3. Remove the back plastic cover to expose the cooling coil. It's called the Evaporator coil.
4. Use a hair dryer to melt all ice off the coil.
5. Put it back together. It should work for 3 - 5 days now at least.
6. Put a thermometer in there. After 24 hrs. the freezer should be 0 to 10 degrees F. and the Ref. side 37 to 44 degree F.
7. Check the door gaskets for tight fit, using a dollar bill for a gauge.
Shut the door on the dollar and try to pull it out in several places.
If it ices up again in a week or two, you have a defrost heater problem. There is a electric heat strip around the cooling coil. This heat strip comes on about 10 minutes every 8 or 10 hours. This heater melts the ice off the coil. There is a clock timer device under the ref. that cycles the heat strip. You may have a bad clock, fuse device or burned out defrost heater strip. The cooling coil must be ice free to work properly.
Jul 06, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Jun 08, 2009 | GE PSS25NGM Side by Side Refrigerator
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
Liebherr Premium CTP 3153 Top Freezer Refrigerator Logo
526 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
