Question about Brother HL 1440 Laser Printer
Noise and not printing
Printer makes a sound like not catching paper, installed a new drum, and still not printing. Any suggestions?
  • bweaver Feb 08, 2008
    Same problem...it sounds like it can't catch a peice of paper, then just stops. The Red Alarm and Yellow Data lights are on.
  • 56 Answers
Hi, What lights are blinking or solid when this happens?
Posted on Dec 05, 2007
Noisy printer
The printer or the drum/toner unit may cause the grinding or clicking noise.
  1. Power off the printer and open the front cover.
  2. Remove the drum/toner unit and close the front cover.
  3. Power the printer back on.
If the grinding or clicking noise dose not occur when the drum/toner unit is removed from the printer, then the drum/toner unit is the cause of the noise. Install a brand new drum unit and/or toner cartridge may be necessary to stop the noise.
Still having Problem Then follow Us For
Brother Printer Support
Feb 25, 2014 | Brother DCP Office Equipment & Supplies
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
Since i install a new drum, i have smudges on my copies how do i fix
    Sir/Madam
    If you have Brother Printer print quality problems, Then I suggest You clean the Your Brother printer drum unit as follows:
    Small Spots on the printed pages:
    If your printed document has any small white or colored spots, follow the steps below.
    1.Open the manual feed slot cover.
    2. Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
    3.Using both hands, put one blank sheet of paper in the manual feed slot until the front edge of the paper touches the paper feed roller. Wait until the machine automatically feeds the paper. When you feel the machine pull in the paper, let go.
    Note
    • Make sure that the paper is straight and in the correct position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
    • Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
    • Do not put paper in the manual feed slot before the printer is in the Ready state. An error may occur and the printer will stop printing.
    4.Make sure that the printer is in the Ready state. Press + or - to choose "Color Correction". Press OK.
    5.Press + or - to choose "Drum Cleaning".
    6.Press Go. The printer will pull in the piece of paper and start cleaning the drum unit.
    7.When the printer has finished cleaning, "Completed" appears on the LCD.
    Press Cancel so that the printer returns to the Ready state.
    8.Repeat steps 3 to 7 two more times using a new blank sheet of paper each time. Upon completion, please discard the used paper. If the print problem still remains, please go to the Step 9.
    Large spots on the printed pages:
    Hint If your printed page has colored spots at 94mm (3.7 in) intervals, please follow the step below.
    1. 9.Turn off the printer power switch.
    10. Fully open the top cover by lifting up on the handle (1).
    11. See the print sample to identify the color causing the problem. The color of the spots is the color of the drum you should clean. For example, if the spots are cyan, you should clean the drum for cyan. Take out the drum unit and toner cartridge assembly of the color causing the problem.
    Caution
    • We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
    • To prevent damage to the printer from static electricity, DO NOT touch the electrodes shown in the illustration.
    12.Push down the green-labeled lock lever (1) and take the toner cartridge out of the drum unit.
    Caution
    1. Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
13.Put the print sample in front of the drum unit, and find the exact position of the poor print.
14.Turn the drum unit gear by hand while looking at the surface of the OPC drum (1).
15.When you have found the mark on the drum that matches the print sample, wipe the surface of the OPC drum with a dry cotton swab until the dust or glue on the surface comes off.
DO NOT clean the surface of the photosensitive drum with a sharp object.
Note Make sure that you put in the toner cartridge properly or it may separate from the drum unit.
17.Slide each drum unit and toner cartridge assembly into the printer. Make sure that you match the toner cartridge color to the same color label on the printer.
C- Cyan, M- magenta, Y- Yellow, K- Black
18.Close the top cover of the printer.
19.Turn the printer power switch back on.
If your question was not answered, please check...
Clean the drum unit Brother
Or
If You still need Brother Printer Help I suggest You follow Us On for :
Nov 07, 2012 | Brother Dr420 Black Drum Unit Cartridge
Printer not catching paper
You may have to clean the pick up rollers with alcohol or put a new roller in your printer.
If you have a printer with a tray, make sure it is set correctly for the paper you have installed.
It will try to grab the paper a number of times and will usually give you a paper jam error after a number of tries.
Jul 13, 2010 | Dell 922 All-In-One InkJet Printer
Brother Laser Printer, paper gets stuck and printing wipes off.
Opened up the back and found there is a plastic cog wheel on the end of an orange drum, which must be the Fuser Unit, which was damaged. So the paper was getting as far as the drum but the rollers to pull it through the Fuser Unit were not going round. A new Fuser Unit seems to be about £99 plus VAT and I don't supose a new printer is much more than that. So if anyone has a spare Fuser Unit for a Brother HL 5140 which is still in good working order I would be happy to consider buying it. Alternatively I have 2 x spare drums DR3000 and 1 x toner TN3060 for sale !!
Oct 25, 2009 | Brother HL 1440 Laser Printer
Hp2820 noise when printing
Try substituting a new imaging drum. The problem may be a bad bearing.
Oct 09, 2008 | HP LaserJet 2820 Printer
Brother 5250DN printer noise
Check my solution here:
http://www.fixya.com/support/t641678-paper_tray_noise
Here's a solution for you with Brother HL 5250 D/DN/DNT
Change the paper setting tab in the tray to make sure you have a small gap between the top part of the paper and the bottom part.
so if this is the old settings : |paper| --> you want to make it: | paper| so you can have slide the paper back and forth.
DON'T adjust the setting to the next paper size because the roller wont catch the paper if it slide too far.
Good luck to all.
Nov 02, 2007 | Brother HL 5250DN Laser Printer
OKI c5150n I get an error that the printer cannot detect the C drum unit.
It sounds like a defective drum unit. Also make sure you are using genuine oki supplies.
Jun 01, 2007 | OKI C5150n Led Printer
No Print on Paper
It sounds like you need a new electron or electrode I forget exactly what they call it, this negatively charges the paper as it passes over the positively charged toner drum allowing toner too stick to the paper where required, the lower the negative charge is the less toner that can positively stick to the paper, creating a light black or grey print. This generally occurs with age but should not be too hard to replace by yourself, just expensive.
May 17, 2007 | Dell 5100cn Laser Printer
Brother HL 1440 Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
