Question about Canon EOS Rebel K2 with 28-90 lens 35mm Film Camera
Developed picture quality
My camera has a black streak across the top of the pictures i have taken.
Its a problem with the sync speed. i just learned about this in class. if the shutter speed and sync speed and not synchronized, often they turn out like this.
for example, if your sync speed (in flash) is at 1/60th of a second, (1/60th is what it normally is but read your manual to be sure) and your shutter speed is set faster, like 1/250th, the time the curtain in the body of the camera is going across the frame youre shooting wont be in sync with the flash so you get the black line.
if using flash, or fill flash, in automatic, you can adjust the aperture, but when adjusting the shutter speed make sure you dont set it faster then your cameras sync speed. you can always set the shutter speed lower, just make sure you use a tripod or flat surface to balance the camera pom. to keep the camera steady, because camera shake starts at speeds after/lower than 1/60th.
hope this helps.
Posted on Jun 22, 2008
Red eyes
Posted on Jan 28, 2008
How to fix olympus fe-340 streak and peaks verticaly when picture taken
Not sure you can fix this, but most of the time the stripes are produced in a dark environment with one or a few bright lights. The streaks start on the bright light. Most of the time if you shoot the picture the streaks are not on the picture.
You could try to switch the camera to the automatic, or perhaps night scene.
If the streaks are there in normal light, I think your camera is defect.
Jul 27, 2014 | Olympus FE Cameras
My sony cybershot t90 got little wet
The actual working part of the camera is not affected as the picture is taken properly. But the display part of the camera is only affected.The wetness might have penetrated across the sides of display screen to the inner parts.The display part needs replacement..
May 23, 2010 | Sony For Cybershot Dscwx1 Tx1 T90 T700...
Yellow black and white lines streaking across the screen
tyr to factory reset device on advance settings
with out the memory card
Apr 29, 2010 | Casio Exilim EXZ75 Digital Camera
Half of the picture is black on every picture.
If the affected photos were taken using a flash then you simply had the shutter speed set too high. The fastest shutter speed you may use when using flash is 1/90th of a second; with anything faster the second shutter curtain starts to travel across the film plane before the first one has fully crossed so only part of the negative is exposed.
If they were taken without flash then your camera has a faulty shutter assembly which must be replaced. It's not a DIY job, it's not cheap, and on a consumer grade 35mm SLR like any of the Rebel/EOS triple digit models it's usually not cost effective. Especially when there are millions of them lying unused and regularly available for next to nothing on auction websites and for absolutely nothing on FreeCycle/Freegle.
Please take a moment to rate my answer if your question has been resolved, or add a follow-up comment for me to reply to if my answer does not meet your needs.
Apr 14, 2010 | Canon EOS Rebel X 35mm SLR Camera
I cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Nov 19, 2009 | RIM BlackBerry Curve 8520 Smartphone
I dropped my IXUS 70. Display screen has black section.
You have a bad CCD. The CCD is like film, it is what the light hits that actually convert an image to a picture. This is a repair as a rule that is more costly than what your camera may be worth.
Jul 03, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Black line across top of all my developed pictures
You have light leak somewhere to the film.
Usually from the bad film door seal.
Mar 29, 2009 | Canon EOS Rebel GII with 35-80 lens 35mm...
Canon IXUS 430 pink on white sections of picture
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras for this free repair include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 03, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Bad picture developing
Since this happened on two seperate rolls of film, the problem may be that the shutter blades have been bent out of place.  This can cause the symptoms you describe.  Have a qualified technician look at the shutter.  Usually the blades can be reset.  In bad cases the blades may be bent or creased. If this is the case, the shutter may need to be replaced.
Oct 23, 2007 | Nikon N55 35mm SLR Camera
Canon EOS Rebel K2 with 28-90 lens 35mm Film Camera Logo
109 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
