Question about HP Officejet Pro L7680 All-In-One Printer
Scanning Unable to scan and fax original
    Novelist:
  • 79 Answers
U can try to make a copy from the pritner first , in case u can do that. Then u can try to reset the printer to its factory defaults .
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7 Allow the all-in-one to re-initialize. This may take a minute or two.
8 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
NOTE - in case the issue is with top feeder then use the ok and cancel key combination.
Thanks
Posted on Jun 06, 2008
My HP 6700 says "unable to scan copy or fax.Can you help ?
There can be several reasons, so to help you troubleshoot the issue about unable to scan copy or fax, it is recommended to download and install 'Hp Print and Scan Doctor' from the link below:
http://support.hp.com/us-en/document/c03286146
Also, you can find more troubleshooting steps mentioned on the link.
GuruAid.com
Apr 08, 2016 | HP Office Equipment & Supplies
Cannot send faxes
check whether you have loaded the scanner software .
Sep 03, 2008 | HP Officejet 4215v All-in-One Printer
IseMY Hp all in one 4355 printer is unable to scan
The HP Officejet 4355 can print, scan, copy and fax.
You need to install the printer software to print and scan. Copy and faxing does not required software installation.
Regards,
Rizwan
Feb 11, 2010 | HP Officejet 4355 All-In-One InkJet...
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Have no manual; need help using scanner and fax
Here is the link given to the user manual. that contains the optimum solution to your problem and maximum guidance.
http://www.devicemanuals.com/guide/All-in-One%20Products/HP/HP-PSC-950-All-in-One-Owners-Manual-==TVRFME56VTI=.html
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=34579
May 27, 2009 | HP PSC 950 All-In-One InkJet Printer
Unable to enter faxes while the machine is either sending or rece
turn off
Real Time Transmission
When you are sending a fax, the machine will scan originals into memory before
sending. Then, as soon as the phone line is free, the machine will start dialing and
sending the fax. If memory becomes full, the machine will send the document in real
time (even if REAL TIME TX is set to OFF).
Sometimes you may want to send an important document immediately, without
waiting for memory transmission. You can set REAL TIME TX to ON.
1 Place the original face down in the ADF.
2 Press Menu, 2, 2, 6.
3 To change the default setting, and then
press or to select ON (or OFF) and
then press Set. Go to Step 5—OR—For
the next fax transmission only, press or to select NEXT FAX ONLY,
and then press Set.
4 For the next fax only, press or to select ON (or OFF), and then press Set.
5 Press 1 if you want to select additional settings. The LCD returns to the SETUP SEND
menu—OR—Press 2 if you are finished choosing settings, and then go to Step 6.
6 Enter fax number and then press Fax Start.
May 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Acer 1240UT scanner not working with vista
The new drivers off of HP are a basic version which give you none of the nice features of the 7400c.
The seem to have discontinued the scanner and now just give you a basic set up which sucks.
It will work under the Windows Fax and Scan but don't be looking to scan an individual picture, crop it and save it as anything other than a jpg or bitmap... lessons to be learned, don't lose your original discs!!! does anyone out there have the original software?? please help
Jan 04, 2009 | BenQ 5000U Scan to Web Scanner
HP Officejet Pro L7680 All-In-One Printer Logo
145 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
