Question about RCA 32V550T 32" TV
Picture got bigger
My tv picture got bigger and tv shuts off and on by itself
can i adjust the picture to fit the tv...its cutting peoples
heads and i can read the bottom...
than is able to fit
  • 83 Answers
Yes, you can adjust the picture by using your remote going to settings, or "Adjust" when your t.v. turns on and off by itself could have'ft to do with nasty weather near you, or the cord is loose and it needs to be pushed in all the way.
Posted on Nov 29, 2007
SOURCE:
I have a Sony kp-51ws500 that shuts off and blinks 8 times, I'v read that some other people have had the same thing and it was the flyback transformer. Now my tv has just a green screen with no pi
No, the set is prone among other things to issues with the three picture tubes, go to unused video input----screen should be black with only the input label displayed-----in your case with Green screen and or slight diagonal trace lines (if there) the Green screen control itself needs to be adjusted slightly down.
I can tell you if you want how to do that---requires only a screwdriver and 10 minutes.
Dec 03, 2012 | Televison & Video
My Vizio LCD HDTV 32in. doesn't seem to "center" the picture on sports programs so when they have a score box in the upper left corner most of it is cut off and can't be seen. Doesn't matter how I adjust...
This is a common complaint. To be frank I don't have the exact term for your Vizio, but most recent LCD and plasma TVs have the ability to "zoom" or adjust "picture format" (those are two commonly used terms) depending on the signal source and format.
it has to do with the fact that currently there are both classic style format 4:3 signal sources as well as new HD 16:9 signal sources and on top of that it may happen that a 4:3 signal source is distributing adjusted image from a 16:9 or other signal source. Think cinema adjusted to run on classic TV - remember the vertical strip of image with two huge black areas below and above it?
Well the ZOOM or PICTURE FORMAT allows to adjust such an image so that you cut the "void" are by scalling (enlarging) the visible area to fit the whole screen.
A problem then appears when the signal source is normal and showing full screen. Then, because of the enlargement, you start missing some of the picture. Before there was nothing there because it was showing adjusted wide (cinema) format to the TV box format, but when the new TV box format gets enlarged it sure starts missing around the edges.
That's what you're seeing.
More and more TVs do not have the ability to adjust that through the TV itself. Don't ask me why, but they can only do it through the remote.
So if you have an original remote there MUST be a button there that's called ZOOM or FORMAT.
It does the trick.
Hope this helps. If it does do not forget to rate it.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Vizio L32 32 in. LCD HDTV
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
May 02, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
How do you adjust the picture? Mine is zoomed in
Is this set using a cable or satellite box? I looked at the owners manual and did not see any format adjustments. If it is hooked to a box, check the settings there.
Oct 14, 2009 | Sony KP-61S75 TV
Picture NOT Alined
Use the zoom for picture adjustment.
Feb 08, 2009 | RCA D52W23 52" HDTV CRT TV
My tv zooms in and changes the format.
This is normal - you are zooming in on the picture. Most people use the zoom feature to "stretch" a widescreen movie so it will fit the screen.
Dec 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I can never fit the whole picture in my screen. cant read any words and peoples heads are cut off
do you have an old monitor or new?
is your video card driver properly installed?
Aug 06, 2008 | Computers & Internet
RCA 32V550T 32" TV Logo
116 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
