Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Out of a few colors
I've got the mfc 440cn and i've run out of yellow and magenta. that's ok but now i can't print anything at all. Is there any i can change the settings to fix this?
  • Anonymous Dec 14, 2007
    Brother 440CN printer does not print black when one color ink cartridge is empty.
  • 832 Answers
No. the ph needs all colors to run without problems. This prefent the ph from drying out.
If you want to print without any problems in future, replace the carts as soon as possible.
Posted on Nov 29, 2007
SOURCE:
Brother Mfc-5440CN Yellow and Magenta will not print. Opened holes on top of cartridges and still will not print. Can you help me?
Have you executed a forced head cleaning?
Are you sure that the cartridges are correctly placed and the output punched ?
Oct 28, 2011 | Brother MultiFunction Center MFC-440CN...
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
My MFC465CN Wont print, I am missing Magenta will that affect it?
Yes missing the magenta ink will cause it not to print. This is because its a color inkjet machine that uses one printer head for all four inks, so when one of them go empty you will need to replace that one for it to work.
Jun 25, 2010 | Brother MultiFunction Center MFC-440CN...
My MFC 490 cw only prints yellow and magenta. All
You should run a few cleanings. Push the ink button then down arrow for cleaning and push ok.
Mar 27, 2010 | Brother MFC 490cw Color Inkjet...
Wont print
what are you trying to print in black? the best way to test out a black ink is to open word pad and type some thing random and print it and see if that works. if you have a all in one printer u might have 2 inks one color and one black in the printer
Jun 01, 2009 | Brother MultiFunction Center MFC-440CN...
MFC-440CN printer. Colors are not proper
I'd like to help if I can. These printers have 4 cartridges. One black, one magenta (reddish), one cyan (blue) and one (yellow). The text and pictures are printed with a combination of these inks. When one or more is low, printing will be as you described. Your situation seems to be that you are out of black (so the cyan is trying to help and can only print blue) and you are probably out of yellow so the magenta is trying to do what it can. If you'll change all of the cartridges, I am pretty sure that you will have your problem solved.
Finally, there is a great place to get cartridges for your printer. The link is:
www.monstertoners.com/dcp-130c.html?gclid=CN2s_uiEsJgCFRIcawodQz_rUg
You can buy a multi-pak consisting of 4 black and 2 each of the three colors for $39.95 plus s/h
I use the cartridges and they have proven to be reliable.
If my help has been satisfactory, please give me your rating.
Jan 20, 2009 | Brother Multi-Function Center MFC-240C...
Mfc 665-cw magenta clogged?
Do you use some very cheap generik ink?
If your ink wont match the specifications of the needed one clogging is the result.
If you have tried several cleaning there is unfurtunately nothing more what you can do: the ph is dead (for mag).
Mar 28, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC-440CN won't print color
Did you use generic carts?
Do use only original brother ink carts!
Only these have special cleaning fluids mingled with the ink.
There are several advantages, too:
You can run a special cleaning mode (DO insert original carts at first!!!)
Press menue then start bk copy then fourtimes arrow-up.
machine should switch to maintenance mode (buttons will flash).
press 7 then 6 then 4 then start bk copy. machine will refresh ink within the tubes and the print head and run a special cleaning routine. when finished press 7 then 6 then 3 then start bk copy to run a power cleaning. leave the maintenance mode by pressing 9 then 9.
The machine should print without proböems. If there is a poor quality left, the printhead is affected by bad ink and cant be fixed anymore.
Jan 24, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
64 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
