Question about Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony KV-34HS510 blink codes
Tv blinks 6 times no picture or sound. what would it cost to repair tv .
  • 6 more comments
  • doorman45 Nov 29, 2007
    what would it cost to replace the c515&c516 the jungle ic&ic206 ontheKV-34HS510 model tv
  • doorman45 Nov 30, 2007
    can an amateur repair tv or should you have a tech repair.could you explain step by step how to replace the two MCZ3001DB chips on D board.
    can you explain step by step process on how to replace these two chips on the D board. MCZ3001D
  • doorman45 Dec 17, 2007
    can you send me a full blown view of motherboard section where the MCZ3001D chips are that need replacing. When replacing chips do I need to do anything to protect to set to keep my my self from being electrocuted?
  • slackkeymike Feb 13, 2008
    I have the same problem. I have ordered the chips from acme. (they did not have a "B" on the end). Which board is the D board?
  • Anonymous Jul 31, 2008
    6 blinks the tv is not turning on
  • Dineros Dec 01, 2008
    I have 4 blink set? What is this symptom telling me?
  • hucklebuck May 11, 2010
    what is the standard cost for this? So I dont get ripped off. What should the range fall in
    Novelist:
    Champion:
  • 232 Answers
I would question that diagnosis, Did you get it online somewhere or did you have a tech check your B+ voltages ?
6 blinks is almost always caused by 2 chips on the "D board", they are both marked MCZ3001D you can order them here if you are a consumer not a tech 800-575-9833. Not to say that the jungle IC & those 2 caps couldn`t cause a dead set symptom but these 2 IC`s are notorious for the 6 blink code, I have personally fixed approx. 10 sony sets with the 6 blink code with those IC`s, hope this helps
Posted on Nov 29, 2007
  • 1 more comment
  • Larry Eastman
    Larry Eastman Nov 30, 2007
    I`m a tv tech so of course I recommend you call one, if you are proficient at un-soldering and re-soldering components and you have the soldering equipment you can replace them,
    1) mark your plugs that have to be removed
    2) mark down on paper which way the chip is installed
    3) un-solder the IC & install the new ones solder it in & your done.
  • landan02 Jul 11, 2011
    Thanks for the tip. I changed out these two chips and it fix the problem.. Thanks again I appreciate it.
    thanks for the tip. We changed the two chips and it fixed the problem
    Problem Solver:
  • 9 Answers
Plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Posted on Jul 29, 2009
  • rajsainiraje
    rajsainiraje Jul 29, 2009
    plz contect me we repair lcd plasma and projection tvs
    Yogesh-9811440932
  • rajsainiraje
    Yogesh-9811440932
4 Suggested Answers
SOURCE:
pishta68
  • 594 Answers
SOURCE: My Sony KV-34HS510 Tv will not turn on
Sounds like a power supply problem. The TV is failing its POST (power on self test) and tripping a relay to protect itself. Time for a service call :-(
Posted on Feb 13, 2008
  • 106 Answers
SOURCE: Sony FD Trinitron WEGA KV-34HS510 34
  • Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty. Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board). This may help !!
Posted on Mar 24, 2009
SOURCE: Wont turn on. There are 5 and 6 blinking stand by
my sony kv-34hs510 tv wont turn on.ther are 6 and7 blinnking stand by lights.
Posted on Jul 16, 2010
What is wrong a Sony trinitron kb-34hs510 blinks 7 times has power but no sound and no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 17, 2014 | Sony FD Trinitron WEGA KV-34HS510 34" TV
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
TV goes to standby What can we expect to pay to fix it?
HI:
Count the number of red blinks on the power led, if it is 6 or 7 blinks then pauses and then does the same amount of blinks then ther is a problem with 2 IC's that needs replacing on the D board. To repair this including parts should not cost more then $150.00.
Jun 10, 2011 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony TV WEGA wont turn-on. stand by LED
line o/p transformer &transistors are gone .. any service person can replace them
Apr 22, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony FD Trinitron WEGA KV-34HS510 ... does not power up.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.This may help the solution or let no what is wrong!!
  • Jan 16, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
    Same as all, sony blinks 6 times..how do i fix the problem
    Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
    Jan 03, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
    Sony trineton KV-34HS510
    let me know how many times standby light flashes. this info will help me to assist you to resolve tv problem.
    Sep 05, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
    KV-34HS510
    Isnt it interesting that I see these 6 and 7 code problems all happening within a timeframe. Seems to me Sony has a problem if not rigged it to die after a certain amount of time.
    Mar 15, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
    Sony FD Trinitron WEGA KV-34HS510 34" TV Logo
    2,418 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
