Question about Intel Motherboard
ASUS P5N-E SLI AND A GF7600 ..BOOTING PROBLEMS ..CORRUPTS
Guys i really need your help after problems with my ecs board and set up i thought sod it build a new one anyway ,.im using my old drives on my new build i built it today along with a new gt 7600 gt pointof view card
i cant boot into windows gets so far in safe mode then restarts same in normal mode,,then u get scrabled graphics like my graphics card is up the pan,,,im not sure its a bios issue with my new asus p5n-e -sli is there anything i can check in the bios ,,or update..its a new board new cpu new graphics card and case...as i say i can get into bios..but for some reason its boots then for 30 secs reboots or goes into scrambled graphics ...i tryed different memory same probs...so werid....puling my hair out here :)
Think i need to resinstall windows? ..not too sure..
  • gazzauk
    gazzauk Nov 30, 2007
    ok good one ive only send the graphics card back well u never know..even when i tried a fresh install of xp it was flickering all the wey intstall so could be what you say im not sure ..any info its greatful cheers dude
  • mulenga benjamin
    mulenga benjamin Dec 12, 2007
    when i turn on the power it just freez at the ASUS P4P800 SE logo,it cant go to the bios set up so  what can i do.
  • 156 Answers
Yes once you change the hardware especially motherboard and graphic cards you must reinstall the OS. It would be better if you format the harddisk completely(atleast the system drive) before using it.
So try to install windows again
Posted on Dec 04, 2009
    Novelist:
  • 231 Answers
Hi, trying to boot from your old drives is the problem.
The Boot sequence for your new board are different from the ol one. Your sequence to get your system going is to load the mobo drivers first, then run your XP disk again and at the second prompt select REPAIR this will run the same as a normal install but should save your existing data and settings.
One problem you may have is activating XP as Microsoft do not approve of multi installs and the new board will show as a different computer.
Regards mistyman
Posted on Nov 30, 2007
SOURCE:
Asus p5n-e sli will no longer stay on for more then a few seconds
You go to AVIRA dot com and download the boot tool, or go to BITDEFENDER and run an online scan, you don't put in a new HDD just because you had a virus, it sounds like you had a problem and thought it was a virus.
Read you manual, plug in the Sata drive into Sata 1.
Do you mean BIOS post, if you don't even see the BIOS post, check your monitor with another PC.
There is only one correct power switch pin, a , + and - pin, how can you switch, there is no such thing as switching.
Dec 15, 2012 | ASUS P5N-E SLI Motherboard
Drivers for p5n-e sli motherboard
You can download the drivers here:
http://support.asus.com/download/download.aspx?SLanguage=en-us
In the upper left hand corner of the screen, type in the model number of the board (P5N-E SLI) and use the drop down to select a category (probably "All"). Good luck.
Oct 17, 2010 | ASUS P5N-E SLI Motherboard
I need a installation manual
Hi there Samurai2,
Please click here to go to the official download site of Asus for the P5N-E SLI model.
http://usa.asus.com/product.aspx?P_ID=KyHOsOKWujC2QguJ&content=download
From the site, select your OS and it will show you the list of download resources for the board. Click to expand the MANUAL and look for the English version.
Hope this helps.
Mar 05, 2010 | ASUS P5N-E SLI Motherboard
I lose my mother board driver cd
Access the manufacturer's web-site:
In the top-left corner, put 'P5N-E' into the search-box, and do the search.
In the next window, click on 'P5N-E SLI'.
Select "Windows XP".
Select the driver(s) that you want to download.
Nov 09, 2009 | ASUS P5N-E SLI Motherboard
I have a p5n sli motherboard which refuses to boot
Go to page 2-30 section 2.4.5 in your manual.
If you are using the onboard graphics for your display set this to [PCI]. If you are using the PCI-E video card, set the bios to [PCI-E]. Save & exit the bios. You should have display after the system re-boots. If you still have no display & you are 100% sure your monitor functions than the video controller on the board is bad. This can not be repaired.
Mike
Jul 31, 2009 | ASUS P5N-E SLI BULK PACK of 10, Quad,775...
P5N-SLI
HI stukove2000,
What is the 5200 stand for?
Here is Asus approved CPU list link for the P5N-E SLI MB:
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5N-E%20SLI
The Corsair TWIN2X2048-6400 5-5-5-15, should work just fine on the Asus MB.
Here is an expanded approved Qualified Venders List from Asus.
http://www.asus.com/999/download/products/1474/1474_10.pdf
You can also see a smaller QVL list in the manual on page 1-18 & 1-19.
The QVL insures total compatibility with the motherboard.
The NVIDIA GeForce 9600 GT will run just fine on the Asus MB. Just make sure your power supply is no less than 500W. A 600W or 650W is preferred.
http://www.google.com/products/catalog?hl=en&q=600W+power+supply&um=1&ie=UTF-8&cid=1841721063482288764&sa=X&oi=product_catalog_result&resnum=1&ct=result#ps-tech-specs
Here is a write up of the Asus mother board: http://www.techspot.com/review/43-asus-p5n-e-sli/
Asus FAQ's of the P5N-E SLI. Good place to check questions about the board.
http://support.asus.com/faq/faq.aspx?model=P5N-E%20SLI&SLanguage=en-us
Good luck stukove2000!
Any more questions?
Mike
Oct 08, 2008 | ASUS P5N-E SLI Motherboard
New motherboard and graphics card can only get into bios scrambled graphics any ideas gurus???
when inin safe mode the grapics card will intialize in default mode please reduse the resolution if that doesnt work that means u dont have the orginal driver for the graphics card please find the orginal driver version which is compactable with ur OS versionand ur graphics card
Nov 29, 2007 | EliteGroup P4M800PRO-M Motherboard
Intel Motherboard Logo
90 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
