Question about Panasonic DMR-E50 DVD Recorder
Problem with the Remote
My remote control is not working. It show a message in the screen of the DVD with "2 CHECK REMOTE" I folllowed the steps in the manual to fix the problem but nothing seems to be working to resolve the problem. Any ideas? Please help..
It works. thanks
Posted on Jan 13, 2008
Try holding the 'ENTER' button and the '2' button down simultaneously for ten seconds. It worked for me.
Posted on Dec 15, 2007
SOURCE:
Afstand bediening werkt niet meer
Step 1:
Check the light on the remote
, press a number. If the light is on, go to step 4. Not light, then go to step 2.
Step 2:
Check the batteries
Make sure the batteries are full and correct in the remote control. If the batteries are full and correct in the remote control, but the remote still does not work, go to Step 3.
Step 3:
Connect the metal parts
Note:
The lower steps are only for the short remote control, see Fig. Do you have a long remote, go to step 4.
  • Take the battery cover
  • Connect the metal parts with a screwdriver or paper clip.Replace the batteries and check that your remote works again.
    It may be that your remote control needs to be reset for use with your TV.
    Step 4:
    Restart the TV receiver
    • Turn on the television receiver in standby mode by pressing the i-TV (top right).
    • Leave the TV receiver 30 seconds as they are.
    • Unplug the TV receiver from the mains.
    • Plug after 10 seconds into the socket.
    • Turn on the TV receiver by pressing the i-TV (top right).
  • Porsche Parts
May 27, 2012 | Denon Televison & Video
Convert daewoo dvd-vcr mod df-4501pn to region free
I did not find any hack for your model, I don't think there is any I will just doublecheck.
Jul 20, 2008 | Televison & Video
Tip
Region free code for Daewoo DQD-200, DHC2200, DHC2300 and Manhattan DVD-2000
1. Press the Open button on your remote control
2. Press the Setup button on your remote control
3. Press the 9 button on your remote control for Region Free, or 1 for Region 1, 2 for Region 2, and so on.
4. Press the buttons 2, 0, 1 and then 0 on your remote control in order, one at a time NB: If this doesn't work, you should try pressing the buttons 3, 0, 1 and then 0 instead NB: If this still doesn't work, you should try pressing the buttons 4, 0, 1 and then 0 instead
5. Press the Step button on your remote control
6. Press the Shuffle button on your remote control
7. Press the Next button on your remote control
To fix low sound output volumes when connecting to your TV via SCART on later firmware versions:
1. Press the Setup button on your remote control
2. Press the Stop button on your remote control
3. Press the Step button on your remote control
4. Press the Angle button on your remote control
5. The word RFOUT will appear on screen briefly and the sound will now have been adjusted to normal levels
6. A secret menu will appear, inside which you can scroll down until the words Debug Item appears, where the current region status is displayed
To convert this player to Multi-Region on earlier firmware versions:
2. Press the Title button on your remote control
4. Press the Next button on your remote control
5. Using the Up and Down buttons on your remote, select the region of your choice or Bypass for region free
6. Save and then Exit the menu
on Mar 07, 2010 | Televison & Video
My remote control for my rca combo 20f510td is not ejecting my dvd from the t.v. .... also actually none of the dvd buttons are doing much of anything when I press them, i.e. the play, pause, eject,...
For remote control concerns. You can try to reset your remote control but be shure before you reset your remote your tv should be unplugged from the power outlet. So here are the 4 steps to reset your remote:
1. remove the batteries,
2. press and hold the number 1 button of the remote control, thus draining all the remaining electricity.
3. put the batteries back in.
4. plug the tv on the power outlet then turn the tv on and try the remote control.
Now if these steps do not work check the warranty of the tv and have your remote be replaced if it's under warranty and if not you can try to purchase a universal remote control that supports RCA tv's.
Sep 09, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
I have a LG HT554PH home cinema and would like a region code to enable it to play region 1 dvds. i have just paid £5 from a website and it is no use my dvd player wasnt on the list. there is a reion...
Hi
To make the player as region free, switch on the LG HT554 Player. Push the eject button to open the tray. Now, press “0” on your player 4 times or until the region code settings shows up on your player. It will show the current region code and will then ask for new region code. Press “0” on your remote to set it as a new region code(0=All Regions). Press Enter key on remote, now restart your player and check the player by playing the DVD’s. It should be region free now.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 23, 2010 | Audio Players & Recorders
Need DVD Hack code for Asda LEDVD0802.
The word Hack gives an impression of illegality, however the term is used in error for what is a series of remote button pressing to unlock the players potential. Sources are freely distributed by the very people who make the units. Now this model I have found is the basics of a Phillips model 610. So here is the unlock sequences..
To change the region on this player 1. Press the Standby button on the DVD player to power off the machine 2. Press the Standby button on the DVD player to power on the machine 3. Press the Blue button on the remote control 4. Press the Play button on the remote control
NB: This and the following steps may need to be carried out quickly following the previous step 5. Press the 1 button on the remote control 6. Press the 5 button on the remote control 7. Press the 9 button on the remote control 8. Press the 1 button on the remote control 9. Press the 2 button on the remote control 10. Press the 1 button on the remote control 11. Press the 2 button on the remote control 12. Press the 1 button on the remote control 13. Press the 2 button on the remote control 14. Press the 0 button on the remote control 15. Press the 0 button on the remote control 16. Press the 5 button on the remote control 17. Press the 2 button on the remote control 18. Press the 5 button on the remote control 19. Press the 5 button on the remote control 20. Press the Play button on the remote control 21. Press the Standby button on the remote control
Hope this works for you.
AndystUK
Nov 08, 2009 | Televison & Video
Unlocking the LG HT303su DVD from region2 to region 0
Hi, I could not get it to work using the other ways, Also I am not sure if this might help I am in Australia region 4 and the below worked for me
(1) Make sure there's no disc in the system and turn it off. Turn the system on again and it will display a "no disc" message on your TV.
(2) Use the remote control: press the "PAUSE" button and then key in the code "314159"
(3) Your TV then displays a menu for choosing the desired region. Select "0" to make your unit an all region player.
(4) Press the "PAUSE" button again.
(5) Turn the system off and wait a few moments before restarting.
Mar 06, 2009 | Televison & Video
Panasonic Dmr es35v VCR/dvd recorder 'Set 1' problem
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Feb 10, 2009 | Panasonic DMRES15 DVD Recorder
Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
mode.
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
seconds.
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
Feb 21, 2008 | Audio Players & Recorders
Remote control not working
Look into your manual that came with your dvd recorder for DMR-E80H, Page 46, Changing the Remote Control Code. My child played with a remote control as well and reconfigured it as well. In the manual, you have explanation how to configure your remote control again to work.
Nov 17, 2007 | Panasonic DMR-E80H DVD Recorder
Panasonic DMR-E50 DVD Recorder Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
