Ntl handset how do you program ntl handset to work tv`s volume
Visit
http://www.cableforum.co.uk/board/101/33602460-digital-tv-remote-control-instructions.html
full instruction and links to codes needed are here
Posted on Dec 12, 2007
SOURCE:
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Oct 17, 2014 | Uniden DECT 6.0 Cordless Telephone...
My samsung sound surround system is 1000watt and im not benefitting from the volume< it is connected to my tv but how do i turn the sound surround louder by using the volume on my tv aswell as the sound...
You need to program the TV remote to work the surround sound.  You gotta select a button that says AV or Aux on the remote.  Then you gotta input some #s so the TV remote can send the proper infrared beam to the surround receiver.  The codes will be in the users manual to operate different brands of electronics.
Oct 25, 2009 | Audio Players & Recorders
How to change Handset number on ntl vs2000 digital phone
Naming your Handset:
Press Menu and Scroll down to Handset and Press OK
Scroll up or down to Label Press OK
To delete the existing handset name press the Clear button repeatedly.
Enter new name then press OK - confirmation tone
To exit, press and hold Clear button.
The display is disappearing on my phones - does this mean they are terminally ill?
Jul 19, 2009 | Lands Phones
Thomson Digital TV Recorder DTI 6300-16 volume control
The manual is not very clear.
The volume control will work after entering the code for your TV make.
Press TV
Press AV and OK together and wait. The TV button will flash twice eventually.
then using the numeric keypad enter the code ie 0680 for Panasonic,
a list was provided with your instructions.
On entering the code the TV button will flash twice again t confirm.
Now the volume of the TV can be controllled using the buttons on the Thomson remote.
Teletext and other functions like "mute" are now present.
peterh
Dec 25, 2008 | Televison & Video
Ntl d5100 digital answering phone system with 4 phones
I HAD THE SAME PROBLEM BUT HAVE FOUND MY INSTRUCTIONS I HAVE A D5903SE WITH 3 ADD HANDSETS YOU CAN E.MAIL ME ON [email protected] OR I HAVE A N.T.L HELPLINE NUMBER 08702413201 LET ME KNOW IF THIS HELPS WENDI
Oct 16, 2008 | NTL Lands Phones
NTL VS1003 Cordless Phone Problem
You should be able to download a copy of the manual at :
www.cordless-phones.uk.com
Hope you find the solution there!
Sep 01, 2008 | NTL VS1500 Cordless Phone
No ring on handset
It may have lost the link to the base unit. Make a note of all the personal details, stored number, etc., then reset the handset. Do this by pressing the spanner button until the display changes, then press and hold the 'R' (delete) button until the handset resets. You'll have to set it up again, but at least it will link.
Spanner then 1 for ringtone, CID for volume.
Spanner then 2 for keypad bleep, 1=off, 2=on.
both cases press spanner to confirm changes.
Jun 28, 2007 | NTL VS1500 Cordless Phone
Validation
I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
Jun 22, 2007 | GE 28111 Cordless Phone
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Ekse
