Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 Lamp
I took the lower back panel out but don't see the lamp housing. Lost my manual can someone guide me on how to locate the lamp. Thank you much.
  • Anonymous Jan 28, 2008
    how do i find the lamp, i lost my manual, please help, thanks
    Scholar:
  • 38 Answers
The front plastic panel under the screen needs to be removed. It's the whole length of the set and pop's off. You'll see the door for the bulb with that removed.
Posted on Dec 05, 2008
    Genius:
  • 1,153 Answers
What is wrong with set? Is picture too dark? Or is Lamp completely out?
Posted on Nov 29, 2007
SOURCE:
Can not locate the where the bulb is on model # wd-52525
Pull off the lower speaker cover and then the lamp door is located on the left side of the lower portion after removing the outer speaker cover.
Apr 27, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Lamp changing Instructions for tv model wd-52525
Hello
Unplug your Mitsubishi DLP TV and position the unit so you can easily access the back
Locate and remove the screws for the back panel. Do not remove the entire back of the TV but the lower panel only. The screws will be located in the edge of the panel.
Locate the projection box in the center of your DLP TV. The projection box will have a series of wires coming out of it and be attached to the speaker housing with four screws
Remove the four screws holding the projection box in place and slide the projection box out. It will not come all the way out but will slide out like a drawer. Disconnect the electrical wires at the projection box by pulling the connectors apart. You should now be able to see the projector lens itself.
Facing the back of the DLP TV, the lamp box is on the right side of the projector lens. Pull the lamp box to the right and it will slide away from the projector lens
Grab the top of the lamp box firmly and pull it out of its spring holding clips. Replace it with your new lamp box by pressing the new box into place in the same manner as the old one. Finish the job by reconnecting and installing everything you opened or removed
Mar 18, 2011 | Mitsubishi Televison & Video
I have a Mitsubishi WD-52525 and replaced the lamp.
We have runn in to this with this type lamp, And we are a service center so we do hundreds of these. We too have had bad lamps straight from the box so best guess would to take the lamp back Mitshubishi will warenty the lamp for 90 days so act fast
Dec 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tv stays on for about 3 minutes the shuts off
If it is Mitsubishi WD-52525 DLP TV then it sounds weak lamp problem in TV and TV needs lamp replacement.
How old is this TV and did you replaced lamp recently?
Lamp replacement is written in user manual of TV and it is easy work.
Please buy Mitsubishi original lamp for TV safety.
Thanks.
Oct 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Lamp power supply
most likely the main power supply board is bad and has badd 3300uf caps
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Lamp replacemrnt
No the lower panel in the front just pops off and the lamp compartment door is behind the lower panel
Aug 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
I get the same red lamp led indicator, bought the lamp and I am unable to locate the lamp inside the tv, took the lower back panel out and don't see anything that i can make out the lamp housing. is hard to replace the capacitor and where is the power board located. thanks a mill.
Nov 22, 2007 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 New lamp-Code 34-Lamp abnormality?
check that you did not bend you connections on the lamp housing
when you reinstalled have seem this happen
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
