Question about Kenmore 17245 Dishwasher
Kenmore 17245 won't drain.
I have a kenmore 17245 that won't drain, the motor runs but no water comes out. I've checked the impeller and it looks pristine. This model connects to the faucet on the sink.
    Scholar:
    New Friend:
  • 67 Answers
Try blowing into the drain line with a wet/dry vac. This sometimes removes clogs. Otherwise, hold the hose above the unit and fill it with water. If there is no clog the water should appear at the bottom of the dishwasher after a few quarts.
Posted on Nov 30, 2007
SOURCE:
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 23, 2011 | Dishwashers
F 2 comes up it won "t finish the cycle
"F02" is a Long Drain error. This is usually an indication of an obstruction somewhere in the drainage system. In most cases, the drain pump reservoir needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage these small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
May 17, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore dishwasher model 587.1414 does not
Check spray arm for obstructions and if it is clear the motor impeller could be slipping or water system may need a good cleaning with CLR.
Eric
Jan 14, 2010 | Kenmore Dishwashers
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
My kenmore washing machine fills with water but will not wash..it sounds like its doing something then it stops after a while i hear it drain and then stops again..water doesnt spray..I let the dishwasher...
Often these work by reversing the motor which has two pump impellers. One direction will pump the water out and the other will pump it through the spray bar. IF the one pump impeller has broken then that would explain your symptoms.
If this is the type you have, verify that the motor is running reversed from when it is draining. If it is not running during wash time, then the timer is probably at fault. If it is running, check for broken pump impeller for the was direction.
Sep 29, 2009 | Kenmore 24 in. 16193 Stainless Steel...
Kenmore portable dishwasher not draining
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
May 28, 2009 | Kenmore 17459 Free-standing Dishwasher
Kenmore 665 dishwasher will not drain
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 08, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Fills, doesn't pump to sprayer, drains on drain only cycle
Sounds like there is still something in the pump. I am 99% certain this unit has a reversable motor.
Jan 26, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Pump on kenmore elite not pumping water to drain
possible pump impeller may be loose on motor shaft also be sure tank to pump line is clear and pump to drain is clear
Nov 18, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 17245 Dishwasher Logo
153 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
