Question about Maytag Atlantis MAV6260AWW Top Load Washer
Water fills but does not agitate or spin
My Maytag Atlantis fills with water and then doesn't agitate or spin cycle. The unit makes no noise at all. I will position the dial all over the place after the drum has filled up and will get nothing. If I increase the water level size, it will respond to that and then again I get nothing else. Please help. Thanks, Doug
  • foxtrot42 Jun 29, 2008
    I suspect the switch since if I drop the lid it will start to fill. How do I get inside to check the switch connections?
  • 80 Answers
THIS UNIT HAS A DOOR SAFETY SWITCH WICH ALLOWS WATER TO COME IN BUT NOTHING ELSE TO HAPPEN IF THE DOOR IS OPEN I WOULD START BY CHECKING THIS SWITCH.
Posted on Nov 29, 2007
SOURCE:
Won't start
if it filled proplerly and won't start now, it sounds like the door switch is broken, there could be something wrong with the rest of the electrical systems, however i would suggest the switch first. If there is a lot of noise like its trying to run, then its probably your transmission.
Jun 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis 7700 - Noisy agitation/wash cycle from motor
Your drive motor may be fine. Check the water pump that is located in the back behind the small metal door on the left bottom corner and see if thats where your noise/water is coming from. These extraction pumps have bearings casing that gets mangled and locked up. Look right above the flywheel that the belt rides on in the W-pump.
May 09, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Water runs through entire cycle until spin mode
Check the plastice hose going to the water level switch. It is pinched, or has a hole in it.
Repair or replace the plastic hose.
Apr 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6260AWW Top Load Washer Logo
372 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
