Question about HP LaserJet 4600dn Color Printer
HP color laserjet 4600 dtn
Replaced the fuser kit, now I have a printer error code 50.4. It will not get beyond 160mb warmup and asks to turn off the printer and turn it back on but same error message appears.
    Problem Solver:
  • 5 Answers
Diod u changed the power socket in the printer. this due to the raw/ ups power. if not problem withn the dc
Posted on Jan 09, 2008
  • 4 Answers
This error can also be caused by the fuser power supply board RG5-6399-030 or(RG5-6399-030CN)
Your fuser may not have had a problem.
Posted on Dec 15, 2007
  • 56 Answers
It sounds like to me you purchased a bad fuser. Is the fuser brand new or a refurb? If so either way you will have to replace it with a working fuser . Good Luck!!
Posted on Dec 03, 2007
SOURCE:
Hp color laserjet 5500 error 59 ck printer error
list of error codes
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP COLOR LASER PRINTERS 4600, 5500 ERROR 59.3, 59.4 1. A fuser motor error. 2. Replace the fuser drive assembly. 3. Replace the D.C. controller board.
Jan 04, 2017 | HP Office Equipment & Supplies
Getting a 50.6 FUSER ERROR on a HP color Laserjet 9500 printer. I bought the image fuser kit and replaced it. Still getting the error. Suggestions?
check the connector that the fuser connects to for damage. If the plug is intact you will probably need to replace the power supply (Low Voltage PS) C8546-69003 is the part number
on a unit of this vintage the part won't be cheap. A quick search on the net shows it from $350 - $600
Good luck
Dec 04, 2015 | HP LaserJet 9500n Printer
I just replaced the Fuser Kit on the Office''s HP 5500 laser color printer but the error is still there and as in the instructions I never received the question: "Is this a new fuser...
Here is the instructions to reset the fuser maintenance count:
HP Color LaserJet 5500/5550 Maintenance Code Reset Instructions
  1. Press the ? button until the display reads "CONFIGURE DEVICE" and press ?.
  2. Press the ? button until the display reads "RESETS" and press ?.
  3. Press the ? button until the display reads "RESET SUPPLIES" and press ?.
  4. Press the ? button until the display reads "FUSER" and press ?
This should reset your printer and clear the error message.
I hope this helps, if so please rate my solution,
BuddyMc
May 09, 2011 | HP LaserJet 5550 Printer
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Feb 07, 2011 | HP Color LaserJet 3500 Printer
For the HP 4350 laserjet DTN what is the error code 50.5 fusion error tell me. Is it an easy fix?
You need to replace the fuser lamp (or ceramic fuser) and the thermistor.
If you can get the replacement parts, it's an easy fix.
Nov 17, 2010 | HP Office Equipment & Supplies
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
4600 color replaced fuser get paper jam error
Check fuser for broken tabs that would engage sensors.
clean 3 sensors behind fuser with a blowerbrush or makeup brush.
make sure you did not break output full bin arm on back of fuser{happens a lot}.
need more help? just ask.
Aug 14, 2008 | HP LaserJet 4600dn Color Printer
HP LaserJet 4600dn Color Printer Logo
358 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
