Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
No sound My apex t.v. is hooked up to a dish. It was working fine, then I turned it on and no sound? I do get sound when I hook it up to the dvd player? I hope you can help. Karen E. McDonald
    Problem Solver:
  • 7 Answers
How do you have it hooked to the dish? If you are running it in RF switch to audio video.
Posted on Apr 15, 2008
SOURCE:
I'm hooking up an APEX Digital TV and when playing a DVD, the picture is fine, but there is no sound. When on TV mode, sound is fine. Suggestions on how to fix this?
  • Turn everything off. Turn on TV and Select dvd input (Source). Wait 10 or so seconds. Turn on DVD player. Works for me with similar problem. Good luck -
  • John
Jan 17, 2016 | Apex Digital Televison & Video
Need to hook up sayo sound bar to my elment tv and my dvd player together
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and cable box. ... More about : connecting soundbar dvd cable ... SolvedHow do I connectmy Element ELEFW392 TV to my Insignia NS-SB314 soundbar.
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... pretty hook them up and it works' followed by 'why did you buy a sound bar?' Do Ihave to connect sound bar to TV AND Dish receiver? and not to DVD? ... tv bluraysound bar and a DVR cable box together Forum; Solvedconnecting ...
Soundbar to tv [Solved] - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2198401/soundbar.html
Jan 11, 2016 | Televison & Video
I can't get it hooked up.
First connect the RCA cable to DVD player as seen below, At the left side there are 2 yellow sockets, any of them can be used for video, and White/Red for sound, On your TV Side follow the same colors and use Video Input group of RCA sockets.
Good Luck
Sep 16, 2012 | Apex Digital AD-1500 DVD Player
XO VIson DVD 7" works fine but when it is turned
sounds like you might have the wire that is always supposed to have power hooked to a switched power source
is it possible you hooked up power wires wrong
sounds like switched wire is hooked to battery and battery connection is hooked to switched source
only other option would be if ground is hooked incorrectly it should be hooked diretly to clean non painted metallic spot on cars body
if you need more help give me more details and i will try to help more
Good luck
Mar 13, 2011 | Panasonic XO-1515 XOVision Car DVD/CD/MP3...
I have an apex ad-5131 dvd player i want to hoook up speakers to to but how? i dont understand the coaxil i matched all of them by color to color but it still doesn't work
The outputs on the dvd are line level and will need to be hooked up to an external amplifier or stereo receiver in order to make speaker work...all you do is hook the audio output right (red) and left(white) to the amplifier and then hook the speakers to the speaker outputs on the amplifier
Jan 20, 2011 | Apex Digital AD-5131 DVD Player
I bought an HDMI hookup to hook the blueray player I got to my Apex tv. I plugged it into HDMI and then turned the input on my tv to HDMI and after a few seconds it says mode not supported. What is wrong?
The DVD player is most likely outputting at 1080p, where as the TV can only input at 720p. What you can do is hook your dvd player up to another TV, and scale back the output from 1080p to 720p, then try it on your TV again.
Jan 11, 2011 | Apex Digital Televison & Video
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
Tv has sound but no picture.
If it works on DVD but not on your Dish, and when you connected it to another house it had the same problem then it sounds like your input connection is bad on the TV. That is if I am understanding this right. From what I am reading your Dish network is not showing a picture but the audio is working fine. The DVD player works fine on the TV though. Then you took the TV and hooked it to another dish system and it was the same problem. That sounds to me like you TV is having a problem, either that or the cables for your Dish network are bad. Try switching to a different input, like the one the DVD player is on and seeing if it works there. If not, then the cables are bad and you just need to replace the cables. If it does work though where the DVD was working before then your TV input is bad on that port you were hooked to before.
Let me know if you have any other questions and if this was helpful. If you need some more clarification let me know, I hope this is helpful. Good luck and have a good weekend. Get it fixed before the Super Bowl.
Jan 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
APEX 3800 DVD COmbo
My Unit is locked, I don't know how it happen, How do I unlock the Unit?
Nov 27, 2007 | Apex Digital ADV3800 DVD Player/VCR
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
243 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
