my laptop shut down and wont start up anymore.it tries to start up. i brought a new battery,but that doesn't seem to be the problem.it still wont start up.the blue light button that you use to start it stay lit for a second then goes out .
The new battery stays on the shelves for quite some time and probably discharged. Does you ac adaptor work? Make sure it does, charge it up first a bit then start it. If you have voltmeter, you can measure its output which should be around 19 volts. Sometimes the connection to the laptop also gets loose after a while, but make sure the ac adapter has power to it.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
i will try what you said.sounds like good advice.thank you
" - lotus7376
I am unable to get the netbook to boot up. It turns on, I hear the Hard drive humming, but it only...
(More)
I am unable to get the netbook to boot up. It turns on, I hear the Hard drive humming, but it only goes to a black screen with a cursor that won't work either. All I did is leave it on at night (which I did in the past)...it goes into sleep mode and always came back on when pressing a key. This time I had to turn it on. A Blue screen, safe mode, etc came on. I went through allof those steps. Then after shutting down and restarting it would not come up to a blue screen anymore and directly stays black. But I know it is electrically...on. Light is green.
