Question about Microsoft Windows XP Professional for PC
PC halts while formatting hard drive
I'm trying a fresh install of Win XP SP1. Before installing the OS, I use the format utility of XP (CD at boot) to NTFS format my hard drive. However, the formatting gets stuck at 70% every time. The hard drive busy light is lit up solid. But it never gets past the 70% mark.
Should I be using another format utility to fix this problem?
Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
May be your hard disk have so many bad sectors. Replace the hard disk and try
Posted on Feb 23, 2015
  • elanthirayan Feb 23, 2015
    Check your hardisk with another PC. Your hard disk might have error
Your xp boot cd ,seems to be corrupted ,with system files missing,try another boot disk,or continue your installation process,from where your previous 70% ends.
Posted on Nov 30, 2007
Try another xp boot cd,your cd might not be correct,with some boot files missing.
Make sure your hard disk is error free Try formating the disk with FAT first ,if it doesn't work out the try disk utilities .
SOURCE:
Wiped old PC clean with blanco.installed win xp on old pc got response.turned it off black screen stating, blanco starting_ How do I fix
Blanco is a data cleaner utility that erases everything from a hard drive so data cannot be recovered. Unfortunately, this includes the MBR - or Master Boot Record. The MBR tells the comptuer BIOS how to access the hard drive and use it to boot up.
I would suggest performing a full FORMAT of the hard drive so the MBR will be recreated. If you are installing Windows XP from an install CD, you will be given the option of which drive to install the OS to. Delete all partitions that show up, create a new partition and then choose the Full Format option (not the Quick format).
If you are using a restore disk, you may need to download a boot floppy or CD and format the drive first. Boot to DOS, type in
format c:/
Where C: your hard drive.
You can get a boot disk from...
http://www.bootdisk.com/
Apr 30, 2010 | Computers & Internet
How to format hard drive
To format any extended or external hard disk
Right Click the drive (example D:\ )and select the FORMAT Options
Click START to Format the Hard Drive. The time to format depends on size and the condition of the Hard Disk.
Feb 15, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Replaced HD and CD Rom drive, PC will not boot to disk, Do I need to format HD 1st. before loading OS?
Hi Get to the bios screen using F8 or F9, change the first boot device to CD ROM/DVD, then insert a bootable disk into the CD drive and try installing the OS first by completely formatting the HD during installation Win XP and higher OS editions give you the option to partition the HDD Hope this resolves
Nov 05, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Installation for xp problem
all the hardware on the laptop is most likely configured for windows vista meaning it will not allow xp to load up because your hardware cant run it
Oct 09, 2009 | Compaq Presario Notebook
I am unable to install win Xp. when trying to boot from a cd to install fresh win xp ser. 2. system reboot after copying few installation files. The Bios set up shows the Sata Hard Drive but unable to load...
your HDD may be bad. I have had a number of HDD that appear fine in the BIOS but won't format either via the install disk or separately via a Linux boot disc.(You can somtimes hear them clicking on and off [seeking])
If you are mad keen on the drive, then D/L 'Hirens Boot Disc' and boot into the DOS mode (it also has a Mini XP mode).and use the HDD format utlity 'killdisk'. This will remove anything on the drive, format it and set it up ready for a fresh install.
If Hirens Boot Disk can't see the SATA drive then its stuffed.. for sure..
Apr 16, 2009 | ASUS P5LD2-VM Motherboard
System crashed , no restore partition, origionall had xpsp1, have Dell reinstall Cd with xp sp2....will it have to be re activated?
Yes, but it will erase any personal data you have. Let me know if there is data to save and I will give more suggestions.
Apr 13, 2009 | Dell Inspiron 600M Notebook
"cant install win-xp on CQ-60"
Hello.
Hope this helps...
These are the normal steps on desktop computers but
should work in your case too with a fresh installation
1. Enter bios settings and set CD Drive as first boot device
2. After reboot if you are asked if you want to start on cd chose yes.
3. start Win Xp installation from cd.
4. delete partiton on C; drive
5. create new partition
6. Start installation and format the c:drive
7. Follow the installation instructions,,,
Feb 10, 2009 | Compaq Presario CQ60-220US PC Laptop
Install win xp and erase win vista
Would like too know how to erase win vista and install win xp
Dec 29, 2007 | Microsoft Windows XP Professional With...
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
Microsoft Windows XP Professional for PC Logo
194 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
