Question about Sony Playstation 3 (PS3) Console
Vertical blue line in display PS3
When i play my PS3. there is a blue line that scans thrugh the display from bottom to top. it annoying . help!
  • aelmesnaoui Nov 29, 2007
    i own a 62 inch sony wega LCD 1080i. it an 05 or 06 model. i m using HD component cable. i have an HDMI cable but i could not get it to work. when i plug it in there is no sound no picture
The TV is 62 inch spny wega LDC 06 model. and i m using HD component cables. also the blue bar is horizontal not vertical
Posted on Dec 10, 2007
    Problem Solver:
  • 13 Answers
Alright, I do believe i have a solution. But i need to know the brand of TV you own, how old it is, and If your using an adapter, or the regular "Yellow, Red and White" cords.
Posted on Nov 29, 2007
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
I have a thin vertical line about 9"from left side runs top to b
either a bad buffer pcb or display panel, 12 month warranty call panasonic quick
Aug 08, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Lines on the display - Samsung 26''
you need to resolder back the vertical IC and it area..find out if it have bad capasitor or poor joint
Mar 24, 2009 | Televison & Video
Vertical blue line from top to bottom
I was told by one of you that the reason was bad drivers and to remove the software and reinstall it again. Bad advise. The blue line is a sign of dust. We cleaned the unit and the blue line dissapeared. I wasted $15.99 for bad service.
Nov 03, 2008 | HP Scanjet 8250 Flatbed Scanner
Playing blue ray
my solution would be to restore the playstion 3 to default settings unless you have files on your ps3 that you do not want to delete forever.
Oct 01, 2008 | Sony Playstation 3 (PS3) Console
Verticle blue lines, left side
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new one.
Mar 07, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Sony Playstation 3 (PS3) Console Logo
233 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
