Question about Mitsubishi HS-U560 VHS VCR
Bad recording from any source
I have a HS-U560 and the play is fine, however when i record the picture goes between bad and good. Do you thing the record head needs cleaning or is it a worse problem than that?
  • audiofun Nov 29, 2007
    playback is fine, Do you think the record head needs cleaning or is it a worse problem than that?
  • audiofun Nov 30, 2007
    I have an update to my problem:
    i have tried recording using both the L1 & L2 inputs and both are faulty. The picture goes from good to bad and back and forth constantly changing. The picture distorts and changes color, this was observed thru the inputs not recording and recording to the tape. Any help would be appreciated.
  • 2,130 Answers
The fact that both inputs give you a bad recording indicates its something common to both inputs. First thing I would do is try cleaning the heads. It's the cheapest solution to try. There is also an erase head as well, but that is usually not part of the video head. The erase head erases the tape just prior to the record head recording the new material on the tape. Problems in the erase head will cause you to see both what you just recorded and what was previously on the tape. The picture will be distorted and shifting back and forth between the new program and the previous one.
- Jim
Posted on Jan 30, 2008
I own a LG.ADR-620 CD RECORDER, when i record from the in built cd to the cdrw and play back things sound OK, when i record from a external source to the cdrw and then play back i get interference only on...
When you record from an external source, the data transfer may be too slow to produce quality recordings. If you're able to download the external source first, then burn it to disk, it should produce good quality recordings.
Apr 15, 2012 | LG Audio Players & Recorders
Picture rolls on playback
Try cleaning the heads, but it seems like the heads may be faulty, you might need to replace the vcr, they don't cost much these days, the repair might cost more than a new vcr these days.
heres a cheap headcleaner, look for one at local shops, wallmart bestbuy and so on
Sep 24, 2008 | Panasonic PV-V4021 S-VHS VCR
VHS won't play correctly - no picture, muffled low voices
Several things.
Check the tape, by opening the cover, to see if the tape is damaged. Look for signs of crinkling at the edges. This is often caused by the roller being worn on one of the VCR.
If it's damaged there's not a lot you can do.
If there's no damage try taking it out of the cassette box and fitting it in a new 'good make' blank tape tape box, discard the new tape in it. Still no good?
Next step, is the tape a movie/tv made by a commercial company. Or a recording on a blank tape?
Did it ever play? (if a movie) if not suspect a pirate tape report seller to FACT.
If a blank tape, try recording on a blank section. If that doesn't work and your video will record on other blank tapes. The tape has something wrong with it.
Some video recorders will play tapes with bad problems IE bad tracking, that others refuse to play, but you will either have to find one owned by a friend or buy one with that claim.
Sep 08, 2009 | Televison & Video
I'm going to venture a guess that what might have happened is you changed the mode of recording. VCRs record in either short play, or long play, or even super long play. As the length of playtime goes up, the quality goes down, because for short play, a 6 hr tape will record only two, whereas a 12 hour tape will record four hours. More information is stored on the tape, so the quality of picture and sound increase, but a longer movie could be cut off. You can adjust the play-length with the sp/slp buttons on your remote control.
Jul 19, 2009 | Toshiba W522 VHS VCR
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
Recording to Cassette
Most Audio Shelf System follow the same procedures for recording. You need to select your source as if you will just be listening, AM, FM, Aux etc. Thereafter, you need to press Record (sometimes with PLAY) to start the recording. Normally, it will record whatever source is playing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 23, 2008 | Audio Players & Recorders
Replacement Belts for Mitsubishi HS-U560
You can try or MCM electronics corps, or even tritronics INC.
Mar 22, 2008 | Mitsubishi HS-U560 VHS VCR
Using the Misubishi HS-HD2000U
The connection "chain" that you need to have set up is as follows: First the source goes to the HD VCR, then that output goes to the TV...accordianman
Feb 13, 2008 | Mitsubishi HS-HD2000U VCR
While on tv picture out and a loud beep
MAGNAVOX DVD RECORDER MODEL # MWR10D6: Is a piece of junk. Yet another worthless waste material and rescources. In other words they or someone else could have taken the materials and energy used to assymble this thing and used it for some other appliance or device that would actually work. This thing is so worthless that it was environmentally irresponsible for the manufactures to even make it. Now all it's good for is filling landfills.
My suggestion is to do as I am right now and go onto any and every forum, or message board you know about and warn as many people as you can away from this piece of junk and the SCAM that is being perpatrated by Magnavox and whoever else helped them cook up this scam.
I've even made space for a photo of it and description of how sorry it works on both my and pages.
Aug 16, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Televison & Video Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
