It does not matter what the dip setting is as long as they are the same on the remote and the receiver. If you do not know the setting you will have to remove the fan mounting cover and pull the receiver out. Open the receiver and see what the dip setting is. Then set the remote to the same setting.
I bought two remotes for two different Hunter fans. Installed both per manufacturer's instructions -...
(More)
I bought two remotes for two different Hunter fans. Installed both per manufacturer's instructions - (those could be improved in regards to dip switches & jumpers). Situation is that both fan controllers respond to the factory settings no matter how the dip switch settings are changed. One remote control with factory settings will activate both fans & lights no matter what the dip switches on the fan controller are set for. Change the remote's jumpers and it doesn't work even after matching the dip/jumper settings. Haven't tried disconnecting the power to see if this fixes the problem. Know a little about electronics but this one has me baffled.
Having trouble install my hunter 27157 remote for ceiling fan take that back my husband is having...
(More)
Having trouble install my hunter 27157 remote for ceiling fan take that back my husband is having trouble figuring out which wires connect , can anyone help
Since Carrier does not have the original remote for my unit (rfl-03010EH) a distributor sold me the...
(More)
Since Carrier does not have the original remote for my unit (rfl-03010EH) a distributor sold me the new one. It does not communicate with the unit. I see 7 dip switches but no instructions come with it. HELP
