Question about Cyberhome CH-DVD 300 DVD Player
Dvd 300 hi, I hooked up red yellow and white i get a black and white pic and no sound
Move the red and yellow over to the other inputs, you will get sound. I have a black and white picture too. It used to be color. Haven't figured that part out yet.
Posted on Dec 13, 2007
SOURCE:
Which cable should be hook up to tv. Trying to hook up DVD player. I have cable with Red, white, yellow.
hi that"s easy thing. first connect rca wire red white yellow to dvd hook up same colour red white & yellow female rca connection. then use another rca wire connect to your tv be video input in yellow one . red & white be sound input - red to red . white to white. just that. good luck!!
Jun 03, 2011 | JVC C-13920 TV
I connect my alpine cva 1003 to valor dv-169T dvd player. sounds come out but the screen is not getting connected to dvd player. i connect red, white and yellow wires.
if evrything is ok with the dvd (make sure the dvd is working fine), you need to hook up the yellow/ blue wires and yellow / black wires one for parking breack and the other for the breack chek the diagram on top of the alpine radio .
Jun 15, 2010 | Alpine CVA-1003 Car Video Player
When hooking up DVD to phillips flat screen there is no color. only black and white.
Sounds to me like you hooked composite video(Yellow, White, Red cables) into the component video (Green, Blue, Red, White Red) connection on your TV.
Feb 24, 2010 | Philips Televison & Video
How to hook up from TV to recorder
hi there
there are three cable yellow red and white your yellow
cable is the picture cabe and your red and white cabe is the sound cabe plug the yellow cabe in the yellow input and the white and red in the red and white input @ the back ok you recorder now the some go to the tv set it will work 100% now
Dec 19, 2009 | Samsung DVD-VR357
Can not get a picture just sound the cables are connect right
Okay. The is kind of complicated but I think I can explain what is wrong and how to fix it. You need to tell the DVD player what resolution to broadcast on. If you have it hook up on component, I would hook it back up to composit and go through the menu's and tell it progressive scan. IF you have it hook up composite tell it regular scan. Composite cable will only have three ends on yellow, red, and white. Componite have five ends on it. Red, Green, Blue, and Red for Audio, and white.
Oct 17, 2009 | Cyberhome CH-DVD 300 DVD Player
Trying to hook up a Philips 22'' TV to Sony CD/DVD player. Need help. I have a Red, White. and Black connector to go from TV to CD Player. Do I need anytning else? TV model # 22PFL3504D/F7
Usually the Color Red and White is for the audio channels and yellow is for the video but in your case you find black instead of yellow.
So you do the connection as per the instruction given below.
TV DVD Player
Red--------------Red
White------------White
Black-------------Yellow
Jul 25, 2009 | Televison & Video
DVD is playing in black and white
check the norm pal or ntsc,or video format
Feb 17, 2009 | Pioneer DV-333 DVD Player
Hooking up my DVD player to my TV and get sound but no video!
dvd player yellow output into
tv yellow input
dvd player white output into
tv white input
dvd player red output into
tv red input
if still no pic replace cords
Dec 31, 2008 | Televison & Video
PLAYING DVD
check your connections on the back of the tv and back of the dvd player. make sure you are using the proper conections on the back of the tv. if you connect the RCA (composite) cables (red yellow white) you should be going from the red yellow white on the tv to the red yellow white on the dvd player. if you have the component(red blue green) connection on the dvd connected to the red yellow white on the tv, you may get a black and white picture. If this does not work, check the manual for the dvd player and see if there is a way to turn "Progressive Scan" features off, some older TV's cannot handle a progressive scan dvd player.
Aug 13, 2007 | Koss KS2503 System
Cyberhome CH-DVD 300 DVD Player Logo
104 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
