How to change a power jack in laptop? Compaq Presario V2000
Has anyone changed a powerjack for a laptop? How involved is it? Is dead, dont get voltage reading back of the jack, but adaptor is ok.
Cannot find part for it.
  • 3 more comments
  • Anonymous Apr 01, 2008
    i have s Compaq Presario V2000 my dc jack needle is broken and i want to know how to fix it
    i tried to open the bottom cover but it won't open all the way. please could anyone help me
  • Anonymous Sep 25, 2008
    Trying to take apart a Compaq Presario V2000 to repair the power supply input pin, which is broken loose from solder. If I figure it out, I'll let you know how it went. I'm hung up, got all the screws out, taking loose everything I can, but the back is still connected near the screen opening button.
    Wish me luck!
  • blarrio Mar 10, 2009
    I ordered the replacement jack and successfully took the laptop to bits, but I am having problems actually getting the old power jack unsoldered from the motherboard. The laptop was obviously put together by a machine and a soldering iron seems insufficient to get at the joints. I've tried a solder ****** and copper gauze but with no success. Anyone have any idea how I can remove the solder from the holes?
    I ordered the replacement jack and successfully took the laptop to bits, but I am having problems actually getting the old power jack unsoldered from the motherboard. The laptop was obviously put together by a machine and a soldering iron seems insufficient to get at the joints. I've tried a solder ****** and copper gauze but with no success. Anyone have any idea how I can remove the solder from the holes? Unless all the joints are free, the jack won't budge.
  • Anonymous May 19, 2009
    broken DC input jack
  • 31 Answers
I did this myself with my HP laptop and after many tedious hours of work I was able to remove the motherboard, remove the dc jack, and resauder a new one on the board and it worked out perfectly.
If you feel comfortable doing the work yourself first start off by removing the screws on the bottom. You then should be able to remove the keyboard, look for a cable that connects it to the board. Now you should be able to remove the pieces of the case around the keyboard, look for the cable connecting the touchpad to the motherboard. After that you should be able to remove the LCD screen, look for the cable connecting it to the motherboard. Now remove the screws holding the motherboard in and remove the tiny bolts around the external monitor connector and the printer connector if you have one. Now you should have access to the DC jack. You will need to sauder the current one off the board and resauder a new one on. Keep track of the many many screws and try placing the components in the order they came out so will know which ones need to go back in in the proper order.
This is VERY tedious if you are not familiar with working on laptop hardware. You maybe able to find a local shop willing to do this or you can look online for a place that replaces DC jacks on motherboards.
Hope this helps!
Posted on Nov 29, 2007
Remove the power cord, battery and all accessory covers on the bottom. Then remove all bottom screws plus the ones under the harddrive and battery. There are retaining clips around the battery holding area and the front release button. Just use a pocket knife and pry between the bottom cover and the side of the case to break them lose.
I fixed my friends by removing the bottom cover and then soldering the main pin in the back of the power jack back to the rear copper clip. It must break lose after being wiggled. I had to add flux to get the solder to stick. It is about a 30 minute repair after you know what to do.
Posted on Jan 08, 2009
Do you have the instructions with pictures??
Is too hard imagine this procediment, i dont have much imagination, LOL,
Greetings!!
Posted on Jan 07, 2008
How do i change power jack socket for samsung x50?
Posted on Apr 14, 2011
    Champion:
  • 367 Answers
I have the same laptop,and had the same problem.After enough prying,I got the bottom off to find a plactic clip near the LCD latch button.The service manual says after removing the screws on the bottom,lift the bottom off.They don't mention anything about having to pry the bottom off.But I had to.Why all the clips when they have that many screws?That's what I would like to know!Maybe so you will break it,and buy a new one?Or send it to them to be fixed?I have a V6000 manual that said to remove the power button panel,you remove two screws,but there was actually three.The manual helps,but sometimes they do have mistakes.Here is the link to the manual.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00444244/c00444244.pdf
Posted on Sep 29, 2008
The small rubber button on my compaq presario V2000 isn't working. When I open the screen of my laptop the light on the screen will switch on for just a moment, and then switch off. How can I fix it so the...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Mar 08, 2011 | HP Compaq Presario V2000 Notebook
Presario v2000 Laptop dead.
Its may be the problem on ur psu or ur motherboard
Jul 28, 2010 | HP Compaq Presario V2000 Notebook
I need to replace te DC jack P/N PJ-019 in my
almost total disassembly. unsoldering the old jack and soldering new one, like 4 or 5 spots on the jack/motherboard. i just had someone do this for me. found them on craigslist. $45. i had to order the jack from ebay though. it was less than $4
Apr 25, 2010 | HP Compaq Presario V2000 Notebook
Compaq presario v2000 is dead!!!
Well oviously when you dropped it, it had done alot of damage. There is defenently something in there that needs replacement. I can't acctually see the inside of your laptop so i don't know what. Go see a computer pro.
Jun 09, 2009 | HP Compaq Presario V2000 Notebook
I need to replace AC Power Adapter Socket, Where do I find this to purchase??
you may check follow website find your laotop DC jack and chose a good price one.
http://shop.ebay.ca/items/__HP-Compaq-V2000-DC-jack_W0QQ_kwZHPQQ_kwZCompaqQQ_kwZV2000QQ_kwZDCQQ_kwZjackQQ_ckwZPresario?_trksid=p3286.m104.l1199
how to change the DC jack:
please reference the manual page 3-1, to disassemble all covers.
and replace the DC jack.
hope help you fix it.
May 19, 2009 | HP Compaq Presario V2000 Notebook
Compaq V2000 Dead
I also have a v2000 which has suffered the fate in the passed, unfortunately as i'm sure you've already read you will probably require a replacement system board.
May 25, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 no power new dc jack
I think that this can be rated as solved. If it is not solved please let me know.
May 21, 2008 | HP Compaq Presario V2000 Notebook
Laptop dead Compaq / new dc jack
Does the hard drive have to be in for the power to go on? NO
All you will get is the BIOS boot up screen then and error screen saying it can't detect hard drive.
May 20, 2008 | HP Compaq Presario V2000 Notebook
Power supply malfunction?
Remove the battery and try the cord again. Complete with the moving it around. It sounds like you have already diagnosed the loose DC plug adaptor, but the battery could have gone terminal.
Apr 17, 2008 | HP Compaq Presario V2000 Notebook
Testing dc jack on laptop
You are not supposed to get a short on the power you could take out the power socket and try the test straight to the board.
On a board I have that works using my digital meter on the diode setting I get a reading of 1200 aprox and 190 aprox when the probs are reversed.
If you have a dead short and the power socket is ok then likely there is a resister shorted out or a diode or even a transistor chip on the mainboard.
It should be ok to power up while in bits so long as the cpu fan is running.
Good luck Regards Wayne.
Apr 05, 2008 | HP Compaq Presario V2000 Notebook
Televison & Video Logo
4,538 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
