More info would help. First guess would be that the high limit is tripped on the back left hand side. You need to push in the red button. If it does heat-up, you need to determine why it tripped. It will likely happen again within 24 hrs. Could be either the solid state relay sticking or the CC probe not reading the correct temperature and letting it rise above 575F.
We run coffee shop, we already have turbochef conventional oven. We only bake cookies, crossant and ...
(More)
We run coffee shop, we already have turbochef conventional oven. We only bake cookies, crossant and sandwhiches. We are planning to have pizza. Is anyway you make adjustment for Pizza
Vikas: This is Manoj Tripathi. I have the same problem as you. What was the final solution? Manoj at...
(More)
Vikas: This is Manoj Tripathi. I have the same problem as you. What was the final solution? Manoj at 415.939.8500
