Question about Sony RDRGX210S DVD Recorder
Disk loading fault
My recorder refuses to read any disks, formatted or otherwise. Also pre recorder movies etc, Strange enough, when I put a cleaning disk in thinking it may need a clean it read the disk and played the audio instructions.
Please advise me as to what I may be doing wrong.
Thanks,
Ray Bannerman
SOURCE:
SOURCE: disk error
Thanks, I can hear the disk spin. It also makes a knocking sound every 5 seconds while it tries to finalize until it errors and then stops. It's very quiet when just recording. I was thinking the spindle had worn down enough to cause the disk to not spin true anymore but I didn't think about the laser going bad. If it wasn't under warranty I would open it up and see for myself.
Posted on Dec 05, 2007
SOURCE: can not read disk
I just sent my BDP-S300 in with same problem...the tech told me he couldn't duplicate the problem and I think I know why...the fix is to UNPLUG the power cable and leave it unplugged for a minimum of 2-3 minutes...this process clears the internal memory; it seems that if you don't clear the memory, it won't read any disc because the unit thinks the same 'problem' disc is in the drive... (don't simply hold down the power button for 5 seconds - that will 'factory reset' the unit to default settings and you will have to reset your video / audio settings)...you have to physically unplug the unit from the power source...If I had waited a little longer before repowering the unit, I wouldn't have had to send the unit in (obviously the unit was without power during shipping and when it was powered up, internal memory was reset and thus did not indicate any problems). One more trick I learned is this - If a disc won't eject, turn the unit off, and instead of using the Power button to turn unit on, use the Open / Close button...the tech said the unit will then eject the disc before trying to read it...Hope this info helps!
Posted on Jun 27, 2008
SOURCE: Disk will not format
My unit will format single layer DVD but not double layer. Anybody have a solution ?
Posted on Jul 06, 2008
  • 3 Answers
SOURCE: how do I update the firmware on the blu-ray player
See the following URL and follow the instructions to the letter:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=BDPS301&upd_id=3977&os_id=7
Posted on Nov 30, 2008
SOURCE: Sony DVD RECORDER/PLAY WON'T PLAY
Dvd players are only made to last a couple of years(the laser goes bad).If you play scratched disc's it won't last that long.Hopefully you didn't pay alot for the player,and if you did then you can get the laser repaired but its expensive.I usually wait until the things go on sale and pick one up for 20 or 30 dollars.When the laser burns out after repeated use I just buy a new one because fixing them is more expensive and unless you want to continue having problems its easier to buy new.These guys that put alot of money in these units are just wasting their money.
Posted on Jan 18, 2009
My dual wont play cds or dvds
its simple to see where is problem.
1st read one more time formats of audio and video disks ,i mean codec what ur device officially read.(like wma,mp3,mp4,theora.. etc)
2nd then if device can not read disk for which ur sure that are recorded with supported codec or to say in supported format, then leans can be dirty or something is stucked inside,anyway lead u to open and clean laser reading lens inside,with any method.
3rd if disk are recorded in format and codec what that particular device can read,and read even just one disk, then lens are not point to look, then disks can be scrached,damaged or simply no more readable..what can be double checked on some other device.
4th if urs disks are for sure in non-supported format then easy and for free u can convert them in supported format(supported codec) on some computer with most of audio and video converter software,and then record them again,even some software can mannage to read and then record(burn) disks which are not readable any more to normal cd&dvd&bd players.
5th its good to know that is legal and good way to have backup copy of audio and video collection,if what is in use get damaged with tear and wear,or else..so favorite things can be burned or else reused again.
Sep 11, 2012 | Dual XDVD8281 - DVD Multimedia Receiver...
Disk Problem - may be wrong FAT version suggets using monitor ro reformat disk. prior screenc showed message regaridng error 6019 (that was before my bosses started fooling with the system)
sounds like hard drive fail. take the hard drive out and put on a PC as a slave setting. if the PC picks it up, if it does go to my computer and check hard drive for faults using windows tools the hard drive should be in FAT32. if it will not read in window or ask's to be formated. it has lost is FAT32 format. now it can be remormatted but you will need a FAT32 format softwear as windows dont use this now in there firm wear. down load the firm wear from dedicated micro web site. and put the 3 files on the hard drive boot folder zip file and another one cannot rember name not dv file think it say or the not pad just the 3 files. put hard drive back in as master again. and turn on it should restart. will take a bit longer as it will be opening the zip file and loading the softwear. when its done then you can sort out the setting in the menu etc for record etc.if hard drive has failed and no repairable format it 2 FAT32 and do as above with 3 files. should be fine then. allso in the site is a manual read this for the setting.... think 6019 is hard drive fault
Sep 01, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
My Handycam DCR-SR40 messges me that "Movie recording disabled". How do I enable movie recording.
It seems problem with hard disk that need to be formatted, please make sure you have copied/ transferred recorded files in computer or format HD will delete every thing on HD.
Press Menu button on lcd screen and select settings then select HD and select Format, it will take little time to format hard disk.
Now you can record in camcorder.
Hope this will help.
Thanks.
Mar 05, 2011 | Cameras
My camcorder states Movie recording disabled. It is a sony handy cam dvd108. I am using brand new sony mini-dvds. I have tried so far the following things: cleaning the lens, cleaning the pick up lens,...
Hi! Looks like that the camera has a system crash. I strongly suggest that you have it looked at by a qualified technician to check the circuit board of the camera. Hope this helps and thank you for using FixYa!
Oct 17, 2010 | Cameras
Handycam DCR-DVD108 DVD Camcorder: if I get a request to format disc upon re-insertio...
Well this was mostly the main reason the pro film makes like myself decided never to go towards DVD (disk) movie cameras and always stay with tapes like the digital 8 sort.
With disk cameras you are never ever going to be sure you are catching anything, as the disk will spin happy in the camera, but as 1000's have already found your disk will be bland if you put the disk back in the camera next time.
Did you format your disk at start of first use? sore are pre-formated, lots are not and wont record unless they are.
Good luck my friend hope you get it sorted out ok?
May 18, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
DVD will not load/format new disk
I have got exactly the same problem. Thought I had found some discs that worked as the first one formatted, since then all have come up with that crappy error protection message. Samsung really should sort this out.
Mar 25, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
I can't play any DVD's. It keeps saying cannot read.
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 25, 2008 | Panasonic DMR-ES25 DVD Recorder
My dvd recorder keeps ruining blank dvd+r's.
I have suffered the same problems as you describe here. What I believe is this unit suffers from inadequate ventilation. After having this problem I examined the unit and noticed it was hot. What I've done is put 2 small flat blocks on each side of the unit, to basically suspend it so that it can get airflow under and over it, now staying much cooler. Nearly all problems now have gone away. Seldomly, I find it will still exibit the problems mentioned. Frankly the only solution I've found from there is to unplug it for a short while and, upon plugging it back in, and trying again it works flawlessly.
Feb 25, 2007 | iLO DVDR05 DVD Recorder
Samsung DVD Rom drive SD 612B
Its a dvd-rom drive. READ ONLY MEMORY.
That drive will not burn a dvd...it has to say dvd-r/dvd-rw.
or be referred to as a super drive.
Hope this helps.
Aug 21, 2006 | Samsung (SD-612) Internal DVD Drive
Sony RDRGX210S DVD Recorder Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
