Question about Kenmore 11101 Mechanical Sewing Machine
Kenmore 385.16764 New machine--has sewed beautifully til today.  Now my bobbin thread won't catch & there's no stitch at all.
  • spazzy911 Dec 17, 2008
    I just bought this machine couple weeks ago. The first couple times i used it - did not have a problem. Couple days ago about mid-way thru a project - the thread got tangled in the bobbin area, and now the bobbin will not rotate and the thread does not join in the stitch.
    I have tried several times to thread the bobbin with no luck.
  • Anonymous Apr 30, 2009
    I have the same problem with the bobbin. What did you do? Have you corrected it?
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
SOURCE: skipping stitches or won't sew
Re-timing is a possible solution but there is a couple of other possible causes. Bent needles are the first thing to check (but you said you changed needles). Another cause in this machine is wear. This machine has been around long enough for the guides for the needle shaft to have worn. You can check this by grasping the needle clamp screw and pushing it front to back. If there is more play than about half the thickness of you thread you're probably going to drop stitches. To verify this is the problem take a piece of string and loop it around the needle clamp screw and pull backwards on it while sewing. If your machine stops dropping stitches you've found your problem and need to take your machine for service.
Posted on Jan 11, 2009
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
Mongo32
  • 111 Answers
SOURCE: Bobbin wont feed
a. needle in backwards
or
b. needle threaded wrong
Posted on May 04, 2009
louislevel_2
  • 374 Answers
SOURCE: need sewing machince help????
hi;
breaking thread and thread below not hook up by upper thrread, this is due on not properly set up of thread tension,first check bobbins windin35caecd.jpgg see figure.the threads should
be counter clockwise.
the theading on upper set up should prorerly inserted follow figures.7dabcae.jpg
the dial set up tension should start at #3 to # 5
the stitch tension should be set to # 8 to # 12
use trial run for fabrics,diffferent set up in every fabric tru to study before sewing in other fabrics.have a nice day don't forget to rate me.thank s a lot
Posted on May 17, 2009
Bobbin thread not sewing tight
try adjusting the top thread tension one number or letter higher
sewing on a scrap piece of fabric till the stitch looks normal.
Jan 17, 2013 | New Home 2014LE Mechanical Sewing Machine
Bobbin thread shows
have you tried to tighten the bobbin tension spring??
Dec 23, 2012 | Brother PE770 Computerized Sewing Machine
Bobbin thread gets jammed
Is it forming a stitch at all? Do you have your needle set properly and are you certain it is the correct size. it sounds like the hook isn't catching the loop formed by the needle. If changing the needle doesn't help. it might be time for a clean and adjust.
Dec 14, 2012 | Kenmore Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
My sewing machine will pull up the bobbin and looks correct when I start to sew, but then it will not catch it when sewing; therefore, it will not make stitches
Take and rethread the entire machine, sound like it is either the bobbin thread not correctly threaded into the machine or the upper thread isn't being pulled throught the take up lever.
Feb 08, 2011 | Kenmore Drop-In Bobbin 16231 Mechanical...
Kenmore Sewing Machine: stitch not forming bobbin thread problem
sounds like it needs a service call. if you do not have a sewing repair man you use regularly to clean machine the local fabric store should know who you could call.
Jul 20, 2017 | Kenmore Sewing Machines
My new sewing machine, just opened to use, is bunching thread on the underneath or bobbin side when I attempt to straight stitch. What is causing this to happen. Thanks.
re thread the top and bobbin threads
after pulling up the bobbin thread pull both threads to the back and hol them when stitching the first few stitches
with out holing the threads the machine will pull the thread into the machine and bunch the thread
Aug 24, 2009 | Kenmore Sewing Machines
Kenmore 11101 Mechanical Sewing Machine Logo
130 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
