Hi there.....the problem could be ...(a) something traped between the inner and outer drum....usually a bra wire....(b) Debri in the drain pump can result in grinding noise...(c) CRACKED inner drum spider unit..and or failed main bearings..test for this by opening the door with appliance switched off place your hand at outter edge of inner drum and test for lift in drum..there should'nt be any lift at all
regards Sir Galahad
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
thanks for the response think it would be the drum spider unit as i can lift drum from inside
thanks again
" - cathycboyle
Zanussi FS1455W - The machine does not wash, even though it sounds as though it will begin washing,...
(More)
Zanussi FS1455W - The machine does not wash, even though it sounds as though it will begin washing, but then always goes to end. I've pressed all buttons but it always goes to end. What is happening and is there anything I can do. The machine is 7 years old.
