Question about EliteGroup P4M800PRO-M Motherboard
New motherboard and graphics card can only get into bios scrambled graphics any ideas gurus???
Guys i really need your help after problems with my ecs board and set up i thought sod it build a new one anyway ,.im using my old drives on my new build i built it today along with a new gt 7600 gt pointof view card
i cant boot into windows gets so far in safe mode then restarts same in normal mode,,then u get scrabled graphics like my graphics card is up the pan,,,im not sure its a bios issue with my new asus p5n-e -sli is there anything i can check in the bios ,,or update..its a new board new cpu new graphics card and case...as i say i can get into bios..but for some reason its boots then for 30 secs reboots or goes into scrambled graphics ...i tryed different memory same probs...so werid....puling my hair out here :)
  • gazzauk
    gazzauk Nov 30, 2007
    it does not even get that far into windows its gets a little way ..the scarambles pixels i think its the card...i even have the problem when i reboot it scrambles the no signal screen
  • 656 Answers
When inin safe mode the grapics card will intialize in default mode please reduse the resolution if that doesnt work that means u dont have the orginal driver for the graphics card please find the orginal driver version which is compactable with ur OS versionand ur graphics card
Posted on Nov 30, 2007
  • rajesh raman
    rajesh raman Nov 30, 2007
    as u said u can get iin to the safe mode enter the safe mode uninstall the grapics driver and reinstall the drivers with compactable with the graphics card and ur OS in safe mode it will set to default mode so u would be able to enter the safe mode
Hello there please guys help me I bought ecs elitegroup motherboard but it doesn't detect my g210 invidia geforce after plug my graphic cart it shows strange lines
suspect you may need to disable the motherboard built in graphics card and tell it to use PCI graphics adapter otherwise an interrupt conflict in CPU and possible conflict as both devices compete for same computer resources.
Aug 14, 2015 | EliteGroup Computers & Internet
Motherboard problem
The video card that you choose for your system largely depends on your requirements. If you use applications that are very heavy on the graphics, then you should consider a PCI express video card with SLI capabilities. However, if the most graphics intensive thing you plan on doing on your computer is watching a usb 3.0 pci cardDVD movie, then you don't really need one that's very powerful, any standard one should PCI Express card do. In many cases, you might even be able to make do with the card that came with your system.
If you're interested in purchasing a new video card, then it's important that you examine the current capabilities of your motherboard. usb 3.0 pci express card The older motherboards support only one graphics card at a time through an AGP slot. Motherboards today do not support AGP cards. Today, the new standard is PCI express, usb 3.0 pci card which has recently replaced AGP as the favoured graphics
Jun 25, 2013 | Nvidia Bios Chip:ecs Geforce6100pm-m2...
ECS long beep
Your graphics card having some problem ...
Jun 07, 2009 | Soyo AMD KT400 Dragon Ultra Black (K7VX4B)...
Unable to get 1440 x 900 resolution with onboard graphics.
Yes, through bios you can only select VGA but it wont have any effect on what you see on windows, so let bios aside. Is through Windows Display properties that you select all the different resolutions... (RIGHT CLIC YOUR MOUSE OVER THE DESKTOP, SELECT PROPERTIES AND LOOK FOR THE SETTINGS TAB ON TOP, MOVE THE SLIDER AT THE MIDDLE TO SELECT RESOLUTIONS) in windows is where you should have the latest drivers from ECS (now PCCHIPS) for your motherboard's onboard graphics. 1440x900 is widescreen type resolution, only available rather recently by new monitors that support it and so I guess it wasn't included in your original motherboard driver CD. Then it's a must to have the new drivers installed and the monitor's plug and play recognized by windows in order to attain the desired resolution from the card.
Any new AGP video card will be far better than the onboard type. DVI is just a digital type of conector and doesn't have to do with the resolution selection, but it will make the images in the monitor show a little better since there is no signal degradation in digital transfer through the monitor cable.
Jan 04, 2009 | Computers & Internet
ASUS P5N-E SLI AND A GF7600 ..BOOTING PROBLEMS ..CORRUPTS
Hi, trying to boot from your old drives is the problem.
The Boot sequence for your new board are different from the ol one. Your sequence to get your system going is to load the mobo drivers first, then run your XP disk again and at the second prompt select REPAIR this will run the same as a normal install but should save your existing data and settings.
One problem you may have is activating XP as Microsoft do not approve of multi installs and the new board will show as a different computer.
Regards mistyman
Nov 29, 2007 | Intel Motherboard
C1 led post code
try changing your RAM with new one
Nov 08, 2007 | EliteGroup ECS P4M800-M Socket...
Mother board bios update
From datasheet on Intel 82865GV: > The 82865GV does not support AGP. ECS use selfmade "AGP-express" port, which isn`t "real" AGP. It is answer that this motherboard need to support videoadapters by BIOS. Recommendation - do not use this motherboard (and other on i865GV chipset) with "external" graphic.
Aug 03, 2007 | EliteGroup 865G-M Deluxe (865GMV50)...
Help...
beeps on motherboard can mean 3 things: 1. memory out (or corupted) 2. vga card out (or corupted) 3. mother board is corupted try to take out the memory and the vga card and place them back on you can go and read you motherboard manual and look exactly what 3 beeps means..
Mar 17, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4M800PRO-M Motherboard Logo
151 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
