Question about Sony RDR-VX500 DVD Recorder/VCR
Finalizing DVD Hello there, Sure hope you can help me with this. I have had wonderful results with recording DVD's on my recorder, on occasions after the program has been recorded, finalized, it is as if the process was not complete. I continue to finalize again only to loose the program completely and it prompt me that this disk can not be viewed or recorded or something to that affect. Than I have to throw out the disk. I know this works, but after accidentally unplugging the recorder this is when it took place. Any suggestions?
  • Mangold Nov 29, 2007
    Problem: Finalizing DVD
    posted by Mangold on 11/29/2007
I am trying to Finalize the DVD but is not letting me go to Disc Setting, what else i can do?
Posted on Oct 11, 2008
    Problem Solver:
  • 6 Answers
If you unplugged the recorder while this process was ongoing, it probably failed. You will need to record again.
Have a great day! :)
Posted on Jan 19, 2008
When I try to load a DVD-R disk in DVD drive, I get a continuous Load message....
Hi again try another brand TDK R GOOD .cheers Hi a DVD-R IS A RECORDING disc if u have recorded on it . & u r trying to play it in another DVD with out ( FINALIZING ) it .u will get a continuous loading message hope this helps
Feb 01, 2016 | Televison & Video
My centrios edw8020 dvr records o.k. but won't play dvd on any other dvd systems
If the disc is not "finalized" it will not play on other DVD players. The steps to finalize the disc are part of the DISC Utilities Menu. under "DISC OPERATIONS". Choose "FInalize DISC". Instructions refer to finalizing DVD=R disc, so you may want to try this type of disc first and see if it works. Says It can be used as DVD-Video disc but results are not guaranteed. You can not edit disc after finalizing, only playback.
Jan 28, 2014 | Centrios EDW8020 DVD Recorder
When I burn a DVD (R- or R+) on a Sony RDR-GX300 it burns the DVD which plays on that unit only. If I try to play the DVD burned on Sony RDR-GX300 on any other brand or any other Sony DVD player or even on...
On That Type Of DVD Recorder,( RW,R-R+). You Will Have To Finalize The Disk. Finalizing is Necessary When Playing On Any Equipment Other Than This Recorder.Even IF Your Other DVD Equipment IS ( VR ) Format Compatible You Still Need To Finalize The Disk. After Finalizing,You Cannot Edit or Record on The Disk,Make Sure It's In Video Mode.
Aug 11, 2011 | Sony RDR-GX300 DVD Recorder
Hi there, My problem is I have a toppro tpr2000 hd recorder and sometimes when I record and have finished, and press stop I get 'record is finalizing please wait' which then just freezes on the screen....
It won't damage the recording on your recorder it will mean you won't be able to view the disc on a different machine, possibly. The finalizing of a disc ensures the table of contents is recorded on the disc.
Try a better quality disc?
Feb 07, 2011 | Televison & Video
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
HOW DO YOU BURN A DVD ON A SONY DVD RECORDER RDR
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Dave
azsnoopy1@cox.net
Nov 19, 2009 | Sony RDR-GX300 DVD Recorder
Finalizing DVD-R fails, rendering Verbatim disc non-readable
You might try finalizing the disc in a PC using IMGBURN or other DVD recorder software. It couldn't hurt...
tom
Jan 09, 2009 | LG DR787T DVD Recorder
FINALIZING ISSUE
Press FUNCTIONS button;  Select DISK INFORMATION; Select FINALIZE; YES; START; ENTER.
Jul 18, 2008 | Panasonic DMR-E50 DVD Recorder
How to finalizing after i recorded
from page 36 of the manual....on the remote control1.gif press SETUP use the arrow key to select "DISC EDIT" press OK Use the arrow key to select FINALIZE press OK. A confirmation window appears, use the arrow to select YES and press OK. If you still cannot view on a different DVD player, you may want to check to make sure that your disc's are compatible with the new player.
Jan 21, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Won't complete finalizing
SAME PROBLEM AND IVE TRIED ALL TYPES AND BRANDS OF DVDS. IM RETURNING MY P.O.S. , DONT WASTE ANY MORE OF YOUR TIME OFF FOOLING WITH IT
Sep 03, 2007 | RCA DRC8335
Sony RDR-VX500 DVD Recorder/VCR Logo
204 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
