Question about Toshiba Satellite A75-S213 Notebook
Over heating issue.
Any ideas how i can solve the over heating issues. Do i have to open up and clean the dust ? Any advice is helps.
  • 83 Answers
Dust is a main thing inside the computer, or try keeping it off for a while, Usally my computer never heats up I remember the first time i cleaned out the dust, Yuck!
Posted on Nov 29, 2007
Mera computer dispalay nahin day raha is ka processor ka heat sink bhi garam hota hain lekin raam beep nahin hoti aur who dispalay bhi nahin deta fan kee speed teez ho jati hay pleas is ka koy hall batain
open the cpu cabinet and remove the dust by any means.
next, remove the ram, clean the ram, clean the ram slots and put it back.
also, try drying the cabinet as this may be due to moisture getting absorbed in the cabinet due to being in a less ventilated place.
should solve the issue.
Mar 10, 2011 | Computers & Internet
My Hornettek 1TB external hard drive has a fan that has recently started making a loud buzzing noise. Is the fan replaceable? Also is there a way to disable the fan without causing heating issues for the...
disabling the fan will cause heat issues , a replacement fan
fron the manufacturer or a universal from tiger direct
will work.
be sure no dust or debris is causing the noise first.
Oct 04, 2010 | Computers & Internet
My DG965SS mother board just shuts down when it want to. Some times it will just reboot right in the middle of whatever and some times it tries to reboot but freezes on the start back. I have reformated...
I have a intel dg33bu.Have a look at the internel fans.Are they clean.
The processor fan and heat sink need to be clean of dust and dirt.
Last- It may be a good idea to put some fresh thermal paste on the processor.
What you are describing sounds like a heat issue,runs,heats up then shuts down.
Sep 11, 2010 | Intel DG965SS Motherboard
I have a ACER 5735 . The laptop shuts down suddenly while its on and sometimes im not able to switch on the laptop and even if i switch on , then once again the power goes off immediately . What would be...
The reason for the sudden shut down of your computer is because of overheating of the 'case', where the CPU is mounted. Overheating can be due to dust accumulation on the heat sink, which prevents dissipation of heat. The possible solution to combat overheating issue is to keep the laptop dust free by cleaning out debris at the vents frequently. Note that a laptop has a much smaller cooling area in comparison with desktops and hence laptops tend to accumulate dust a lot quicker than desktops. This is because all the dust/debris, in the case of laptops, accumulate in the cooling fins.
Get more information to fix Acer shut down issue :
Hope this information helps you.
Aug 28, 2010 | Computers & Internet
Over heating playstation 3
Playstation 3 overheating is often caused by one of the following issues: poor ventilation of the unit, excessive dust build up in the unit, or a problem with the cooling fan itself. Clean the fan out with some compressed air and make sure it is getting proper ventalation
Feb 28, 2010 | Sony PlayStation® 3 (80GB) Console
I have a 6 year old gateway desktop, it has windows vista. The computer will not stay turned on when i boot up (won't boot up), i also use it as my wireless master and do not have any issues with my...
This might be a heating issue. Considering its 6 years old pop open the case and use dust off and spray it down until there isnt any dust left near, in or around the heat sink. try that and if it doesn't work try re-seating the heat sink on the possessor and clean off all the thermal paste and re apply some new thermal paste.
Oct 25, 2009 | Gateway Computers & Internet
My pc will not power up correctly beeping noises please help
Open your cpu cabinet .
Remove dust from motherbord circuit.
Pull RAM memory then refix it afdter clean dust from it.
Aslo check heating event of chipset.
Reattach all connection to motherbord and harddisk.
Also open processor fan and then processsor then refix both.
Some times beeping noise comes because of
overheating of can put exctra fan for heating event.
Thanks for using fixya
Please rate this solution if it helps.
Jul 22, 2009 | Computers & Internet
Keeps freezing and gets hot
The freezing itself is most likely due to friction and heat created in the hard drive inside the Zune. The excessive heat you feel is probably due to the same problem.
I would suggest (if you are tech savy) opening the Zune (you can look up instructions easily) and cleaning out any dust you see inside the case. There COULD be a battery issue, so making sure the insides are clean and dust free is the first step!
You can use a small can of compressed air (available at any best buy, office max, office depot, etc.) to gently clean out any particles or dust. Best of luck!
Jun 24, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Overheating problem, with fan stopping randomly
If it's overheating it's possible that either there's a problem with the fan, or the fan/heatsink is clogged with dust. If you know how to open up the laptop you can do that and use a can of compressed air to clean it out which may solve the problem. If not you'll have to replace the fan.
Feb 19, 2008 | Acer Aspire 3000 Notebook
Toshiba Satellite A75-S213 Notebook Logo
148 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
