Acer Veriton 7500 PC Desktop
Problem for Acer Veriton 7500 PC Desktop
I installed Linux,and the PC doesnt standby
By drori_gd on Aug 12, 2009
I installed Linux, and I cannot put the PC to standby or hibernation. It worked in Windows.
Maybe because its ACPI 1.0?
Comments:
Aug 13, 2009
- Thanks! now i can standby openSUSE 11.1!
Aug 13, 2009
- soory, after resuming from standby openSUSE freezes
Best Solution
posted on Aug 12, 2009
Very Helpful)
dante777
Rank: Guru
Rating: 91%, 427 votes
Some Linux versions often encounter problems with hibernation. That depends on the combination of which hardware you are using and which Linux distribution is installed.
Look at this posting for example regarding the same problem in ubuntu.
One important issue - and that is valid for all Linux distros - is, that your swap file has to be larger than the amount of RAM you have installed, because hibernating and stand-by writes whatever is in RAM to your hard drive. If you have 2GB of RAM installed, your swap partition has to be at least 2GB.
If you need more help, tell me which Linux version you are using. For now, your best choice is to search the forums for your distribution. There is a solution posted here, but since I haven't tried it, I can't guarantee that it's working,
Before working on system files, always make a copy of your original file in case something goes wrong.
>> sudo cp examplefile.conf examplefile.conf.bak
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Acer Veriton 7500 PC Desktop
Questions and Unsolved Problems for Acer Veriton 7500 PC Desktop
Do you recommend Acer Veriton 7500 PC Desktop?
Answer
Answer
When I plug this computer in a green light flashes in front and back. When I remove the 24 pin plug... (More)
Answer
I'm looking for the motherboard manual for Acer G43T-AM v2.0 motherboard.
Answer
I brought home a computer (hp7800) from work that was on a T1 line and found the internet just fine.... (More)
Answer
where is the dv terminal on a insigia model d400 pc
Answer
pano po ba yung magka kulay yung pag nag cocoment ca para instead of black pink colors
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktops Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
