Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
My partner has run over the power cable how do i release the on/off button housing to rewire it. Dyson dc07
    Sergeant:
  • 271 Answers
To need to take you bin off and top handel off push it up nicely and then you will need a star screw driver and un do the screw its top left side where your top filter would be you have taken it right off so you can do the job better then when you have the little cover off you can see the weirs for the switch you need to unplug the wires and replace them with your new ones you will see what you will need when you get to them ok good luck
Posted on Jan 08, 2008
DC07 Vacuum canister stuck. I won't release so I can empty it. Any suggestions?
You may have to press the release button and hold it depressed as you pry the canister loose.
Feb 13, 2015 | Dyson DC07 Animal Bagless Upright Cyclonic...
How to replace the cord in dyson's dc07
Things You Will Need
  • Dyson DC07 power cord
  • T15 Torx-bit screwdriver
  • Small can
  • Camera or cell phone with camera
  • Flat-head screwdriver, 3/4-inch or smaller
  • Needle-nose pliers
Tips
  • Do detach the black wire that goes to the motor as it does not require removal.
Warnings
  • Do not work on the power cord when it is plugged in.
  • Do not force the plastic-covered connectors from the switch or you could break the male ends. Pull them off firmly but gently to avoid breaking the terminals.
  • Do not apply too much force to the plastic arms that hold the housing in place. The plastic arms are fragile and may break easily.
References
1 - Unwrap the power cord from the Dyson DC07. Detach the handle of the vacuum cleaner by pressing the release button. Pull the handle from the hose. Slide the hose down the wand and push the button at the bottom to release the hose from the machine.
2 - Press the button at the top of the dust bin handle to remove the canister bin assembly from the Dyson DC07.
3 - Lay the machine on with its back with the power switch facing upward. Locate the Torx screw directly beneath the switch actuator. Remove the Torx screw, turning it counterclockwise. Place the screw into a small can so you do not lose it.
4 - Remove the switch box housing held in place by the Torx screw just removed. Carefully pry upward on the two plastic arms that clip the housing in place. Take a picture with your cellphone or camera of the open housing to make it easier to reinstall the wires where they belong in the channels and spaces provided.
5 - Center the needle-nose pliers on the female connectors from the power cord attached to the switch. Apply equal force to pull them from the male ends of the switch. Also detach the two wires that connect together within the housing, identified by the clear plastic connector between them. Depending on your machine\'s manufacture date, the wires might have different colors. For example, they may be white and brown, all white or one could be blue. Disconnect a total of four wires -- two from the switch and the two connected together. Leave the other wires alone.
6 - Trace the electrical cord on the machine until you reach its protective cover where it enters the Dyson DC07. Lift up the cord protector to remove it from the vacuum. The cord protector has slotted sides that fit within the plastic. Slide the cord protector from the power cord.
7 - Remove the plastic covers that protect the female ends on the power-cord wires that connect to the switch. The new power cord does not come with these. Insert the tip of the flat-head screwdriver through the top of the plastic connector with two internal ridges. Lift upward and away to pull the wire free from the connector. Repeat for the other wire. Push the female end into the plastic connector until it snaps into place. Repeat for the other power-cord wire.
8 - Thread the new power cord through the cord protector. If you have trouble pushing the wires through, reach in with the needle-nose pliers to pull both wires through the rubber protector.
9 - Reconnect the two separated wires back together by inserting the male end into the female end of the other wire. Reconnect the two wires from the power cord to the switch. Reinstall the switch housing on the machine. Align the wires in the channels provided to keep them from being pinched or pulled out when you reassemble the housing. Look at the photo you took earlier as a guide, if necessary. Insert the wire that goes to the motor in this channel and the white wires connected together to the left of the switch in the area provided.
10 - Put on the switch housing cover and secure it with the screw you removed earlier. Reassemble the vacuum in the reverse order you dismantled it.
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Aug 27, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
Dc07
hi there.
see if this link helps you out.
How to Repair Dyson Vacuum Cleaners How to Service Dyson How to Fix Dyson
This could be a faulty cable or switch, but could also be a faulty motor.
or this one might help you.
My Dyson Won Turn On Hunker
if you need to read up some more try this link.
Dyson DC07 Bagless Upright Cyclonic Vacuum NO POWER Google Search
Jul 05, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Machine stops working after about 15mins of use.Doesn't feel hot and fuse not blown.Any ideas ??
This is most likely due to a dirty filter. Cleaning:
Turn off and unplug the machine.
Press the release button on top of the back of the powerhead.
Remove the filter housing.
Separate filter from housing.
Rinse thoroughly the following items in cold water: foam, cage, and cloth.
Repeat until the water runs clear.
Air dry for at least 12 hours before reinstalling. Make sure it's completely dry.
Mar 01, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
This is embarassing, but I have just looked at the Dyson DC07 manual and at my Dyson for about 20 minutes, and I can't for the life of me find the wand release button on my actual Dyson.....the manual...
Hi the wand release button is located directly above the the Cylinder release button. The wand release button looks like the picture below. In order to releease the wand you must firstly make sure the Electrical cable is not wrapped up for storage. So unwrap the electrical cable. then find the item as in the picture. Press this button in and at the same time lift the wand. This will realease the wand from the spine of the Dyson. dumfriesdon.jpg
Nov 10, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No power
The motor will have a thermal cut out,however chech your plug fuse and the cable as it enters into the off on switch. its known to snap here within insulation.....
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How to fix a new power cable to a Dyson DC07
http://www.dysonmedic.com/DC07%20Folder/DC07%20Motor%20change.html
if you go through this page you can see how to get to the wire housing and how to get it off
I hope this helps you somewhat
Aug 27, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson cleaner keeps cutting out, no blockage found, filter clean.
1. Check the on/off button these can also be troublesome and if you've stood on the cable once or twice you could have a break in the wire and it's shorting, check by turning on and wiggle cable around where it enters machine.
2. Faulty thermocouple, it is held in a white plastic housing screwed with one T15 torx screw to the motor housing. You could replace it but I just shorted mine with some wire and it hasn't failed since and more importantly not caught fire yet!
May 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
64 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Manchester Vacs
Manchester Vacs
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
