Question about Hotpoint HSS25GFP Side by Side Refrigerator
Noise in my refrigerator
I have a hotpoint refridgerator, the evaporator fan in the freezer is whinning and surging, I was told that is the mother board on the back of the unit that is causing the problem, if this is try how can that cause the noise, is it because the motor is not getting enough electricity. Thanks
  • bnr040 Dec 10, 2007
    I Have the same problem as Ronald's. I was told to replace the evaporator motor behind the back wall of the freezer. I am going to try this repair myself because you can buy the part for about $25.00 at repairclinic.com. Any help as to how to get the back wall off would really help me.
  • militarywife Feb 12, 2008
    We have been listening to this same noise so long that it is finally driving us crazy! I just wrote down the model number off my fridge and sure enough, it is the very same one. We bought this fridge in March '06 brand new from H. Depot. At first I noticed that it sounded like there was a cricket behind it and then it started having this fan noise. We thought it was ice build up on the fan blades, but after reading the description of Ronald's problem, it has to the same thing. I think Hotpoint should recall the product, but that won't happen. We'll try to replace the evaporator fan motor. Thank you!
If I order through repairclinic, what exactly is the p/n for the evaporator motor for this particular Hotpoint model?
Posted on Mar 20, 2008
I replaced the evaporator motor in the freezer, that fixed the problem! part you can order at repairclinic.com
Takes about 25min this job.
Posted on Feb 25, 2008
  • 32 Answers
Replace the evaporator fan motor that will solve the problem
Posted on Dec 18, 2007
Refridgerator has started making a noise. It stops when I open the refridgerator door and then starts again when I close the door.
It's your evaporator fan that is either hitting frost build up or bearing in motor is bad. If blade is hitting frost, you may have a defrost circuitry problem or door gasket problem
Jul 31, 2015 | GE GBS22HCP Bottom Freezer Refrigerator
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
Hotpoint refrigerator sounds like a high pitched siren
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Mar 17, 2011 | Hotpoint HSS25GFP Side by Side...
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
When the compressor is running the freezer makes a whinning noise
Stop the freezer fan and see if the noise quits. The fan runs when the compressor does.
Eric
Nov 21, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
Hotpint Fridge
hi thanks for the question its either the fan blade hitting ice or a bad fan motor remove the floor 4 screws lift from back to expose the evaporator you will see either ice hitting fan blade if this is the case thaw the ice dry the foam and re assemble thanks the appliance doc
Sep 07, 2008 | Hotpoint HSS25GFP Side by Side...
Whinning noise
Evaporator fan motor is located in the freezer compartment behind the back wall. To access it you must remove the shelves and the back wall which is held in place by screws. Then you can remove the old fan motor and install a new one in the reverse order that you used to remove the old motor.
Mar 12, 2008 | Hotpoint HSS25GFP Side by Side...
Noise
I believe you will trace this noise back to the evaporator fan motor inside the freezer making the noise. If you agree that the noise is coming from the evaporator fan motor inside the freezer it is not the motor that is responsible. Your model has a Main Mother Board on the outside rear wall of the freezer down low (about 10 screws hold square cover on over board). The Main Board is causing your noisy evaporator fan motor. Use caution when handling any electronic circuit board. Follow antistatic cautions. Static electricity in your body can damage these valuable circuit boards.
Nov 10, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerator making a whinning noise.
sutty, you have a 2 speed DC evaporator motor in this model. There should be at least 60 seconds between any fan speed changes. On the back side of the refrigerator you have a main board. Unplug J2 connector on the board. Check for 13VDC between pins j2-3 and j2-8, then check for 8 to 13VDC between j2-3 and j2-4. If the voltage is correct I would suspect the evaporator motor. If the voltage is incorrect, then the problem is in the main board. Pins read from left to right 1 through 8. Catriver.
Jun 29, 2007 | Hotpoint (HSM25IFTSA) Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
348 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
