Memorex Mega TravelDrive? 4 GB USB Hard Drive
Problem for Memorex Mega TravelDrive? 4 GB USB Hard Drive
Similar problem - no longer blue light for memorex traveldrive
By srizvi1 on Aug 12, 2009
I have the same problem as others in this thread. Any solution to get data off?
Best Solution
posted on Aug 23, 2009
Very Helpful)
bob_computer
Rank: Guru  Computer Accessories  Expert
Rating: 87%, 1250 votes
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Memorex Mega TravelDrive? 4 GB
Questions and Unsolved Problems for Memorex Mega TravelDrive? 4 GB
Do you recommend Memorex Mega TravelDrive? 4 GB USB Hard Drive?
Answer
Answer
For some reason, my vista computer will no longer support my memorex flash drive. I tried it in my... (More)
Answer
I last used my memorex mega traveldrive 4 gb in April and put it aside. When I plugged it in the... (More)
Answer
Hello, For some reason when I attempt to access my portable vault, reguardless of the computer I am... (More)
Answer
hi, my flast drive didnot deceted at my pc no power on ?
Answer
my memorex USB travel drive (4GB) is write protected and has no lock/unlock option. What can I do to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drives Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
