Question about SanDisk SDMX1 MP3 Player
Screen freezes When I turn on the mp3 the screen says 'welcome sandisc 256mb'.. no matter what button I push or how long I hold them, the screen wont change or let me do anything..I can't even shut it off. I have to take the battery out.. Any suggestions to fix it? I hate to spend and lose money....
  • Anonymous Dec 03, 2007
    I have the 512mb version and I have the same problem, real pisser!
  • dahou Dec 10, 2007
    I tried the solution but it did not work. What other ideas? Even when I take the battery out and replace it the screen is still frozen on the welcome page.
Press rec button, hold, press play button, no release them. Connect the unit to pc via USB. You would see the unit as a drive. THen disconnect the unit and turn it on. These steps would reset the mp3 player... Did it?
Posted on Dec 08, 2007
Upgrade your firmware, it's available in sandisk web ang follow the procedure
Posted on Aug 10, 2008
Format the drive, problem fixed
Posted on Apr 23, 2008
SOURCE:
WHEN I TRY TURNIN IT ON IT JUST STAYS ON THE SANDISK 256MB WELCOME SCREEN HOW CAN I UN FREEZE IT?
Reset the device. 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Power cycle the device.
The power cycle discharges excess/residual power from the player; with the use of a new battery, it should be able to power on the MP3 player properly.
STEP 1 - Remove the battery STEP 2 - Power cycle the player 1. Connect the player to the PC. 2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device 1. Unplug the player from the PC. 2. Insert a fresh AAA battery into the player. 3. Turn on the player.
Dec 29, 2010 | SanDisk SDMX1 MP3 Player
Freezes at welcome screen
Try to scan for viruses , if nothing happened , then try to update firmware !
good luck .
Jan 22, 2010 | Coby MP-C858 MP3 Player
Mp4 player freeze
if you can still see and detect it with your pc there may be a newer firmware update to fix this issue try and find the firmware and flashing utility from the manufacturer and see if that helps
Sep 24, 2009 | Digital Mind Corporation iQ Sound...
Freezing
Creative Zen should have a reset button on the side, it is a very small hole that you will need a pin to push the button inside, hold the button for about 20 seconds. This should reset the player.
Jan 01, 2009 | Creative Labs Zen Touch MP3 Player
Rca h100a mp3 player
http://support.rcaaudiovideo.com/downloads.aspx?product=98
update the firmware
Jan 24, 2008 | RCA H100 MP3 Player
How to reset the mp3 player when it freezes::::
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?region=1
Dec 03, 2007 | Creative Labs ZEN V Plus MP3 Player
RCA TH1011 MP3 player
After it is turned on, you need to push the power button again to begin playing....To shut down, hold the power button....
It's not the best player!
Dec 02, 2007 | RCA TH1011 MP3 Player
Mp3 won't turn off and the screen doesn't work
My Sansa wouldn't turn off and I got it to do so by pressing the center button while holding the main menu button down. But then once I did, it wouldn't boot back up.
Mar 24, 2007 | SanDisk Sansa e200 MP3 Player
Sansa m240
Hi. I'm having the same problem with my m250 and am concerned, since I've only had it for a month. Nothing I do, including removing the battery, hooking it up to my computer again, or holding the power button down for a long period of time works.
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk SDMX1 MP3 Player Logo
219 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
