Question about Brother EM-530 Typewriter
Setting right margain
I cannot get the right margin to set.  I am using the code key + 5.  We are trying to set small margins for use with bookplates.  Because it will not set, we cannot use the center function.
    New Friend:
  • 120 Answers
Some typewriters just have a beep to let you know the right margin is coming. the keyboard might not lock up when it gets to the right margin. you might be able to type right through it. also you may be setting it too close to the left margin.
Posted on Feb 12, 2008
KXR00 I have a panasonic elfec electronic typewriter r200 and I don't have a manual. I am having trouble setting the Left & Right Margins Regaards Lesley
I have a manual...
To clear margins and have do the following: depress the "return" key so the carriage returns to the left margin. Then depressed the "code" "tab clr" keys.
To set margins and tad do the following: clear your margins in tabs using the steps above. Depressed space bar until you reach the desired left margin. Depressed the "L. MAR" key... you're left margin is now set. Depress the "space bar" until you reach the first required tab stop. Depressed the "tab set" key... your first tab stop is now set. Repeat steps 4and 5 for each tab stop required on the writing line up 13 can be set on each line. Depress the spacebar to move the carriage to the desired right margin. Depressed the "r. mar" key. Finally depress the return key.
May 28, 2011 | Office Equipment & Supplies
I have an SX-4000 Electronic Typewriter and use it from time to time BUT I do not know how to reset the margins....basically expand them beyond the norm. Please help - I did do the ALT and then the 4 or 5...
Try this procedure to set and adjust the margin:---- Use the "Space" and "Backspace" keys to set the margins by positioning the carrier where you want each margin. Press the "Alt" key along with the "L Mar" or "R Mar" key, depending on which margin you are setting, left or right.Press ALT with L Mar key to adjust margin on left side.Press ALT with R Mar key to adjust margin on right side. ----------------- For more help.Click this link below and check page number 11:---- http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SX4000_EN_219.PDF ------------
This should help.Thanks.Helpmech.
Jan 05, 2011 | Brother SX-4000 Typewriter
Setting nargins
The keys used for margin control on the brothers is the ALT key just to the left of the space bar, and the #3,4,& 5 keys.
To move outside the present margin to the left, backspace to the left margin. Press the ALT and '3' keys at the same time to bypass the margin. Back space past the margin to the point where the margin is to be set. At the point you want the new left margin, press the ALT and '4' keys at the same time to set the new left margin.
To move outside the present margin to the right, spacebar over to the right margin. Press the ALT and '3' keys at the same time to bypass the margin. Then spacebar over to the point where the new right margin is to be set. Press the ALT and '5' keys at the same time to set the new right margin.
The basics are that the ALT +3 releases margins, ALT +4 sets the left margin at the point of the carrier, ALT + 5 sets the right margin at the point of the carrier.
Hope this helps.
Mar 15, 2010 | Brother ML-300 Typewriter
Changing margins
To change or reset margins, the keys involved are the ALT key to the left of the spacebar, the #keys 3,4, & 5.
The ALT & '3' keys are used to bypass the set margins.
To bypass the left margin, move the carrier to the left margin. Press the ALT & '3' keys at the same time. Release them then backspace the carrier to the point the new margin is wanted. Press the ALT and '4' keys at the same time to set the new left margin.
To bypass the right margin, move the carrier to the right margin. Press the ALT & '3' keys at the same time. Release them and spacebar to the point where the new right margin is wanted. Press the ALT & '5' keys to set the new right margin.
The main thing to remember is to move the carrier to the point where the new margin is needed. ALT + 3 bypasses old margins, ALT + 4 sets the left margin, & ALT + 5 sets the right margin.
Feb 24, 2010 | Brother SX-4000 Typewriter
I need to find out how to make reset my margains AE-740 nakajima
Return to the L. margin, touch and release the mar rel key, backspace to where you want the margin, press L. mar. Key.
The R. Mar works the same.
DickyO
Jan 19, 2010 | Nakajima AE-740 Typewriter
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
What keys do I use the change the left and right margins?
You set the margins by putting the printhead where you want the margin set, and holding down the CODE key, push the key under where L MAR or R MAR is printed, (above the top keys on the keyboard) depending on whether you want to set the right or left margin.
If you want to set the left margin to the left of where it's set, hold down the CODE key and push the key under MAR REL. Then using the Backspace (or spacebar, if you backspace too far) position the printhead where you want the mar. set and holding down the CODE key, hit the key under L MAR.
Setting the right margin works the same way.
Oct 27, 2008 | Brother GX-6750 Typewriter
Swintec 2600 Electric Typewriter
MARGINS: Left margin space or tab to where you want margin set and depress the mar L key. Sometimes the key has to be depressed as you hit the code key. If you want to move carrige to the left, go to margin hit margin release and bk space to where you want. Same with the right margin only use th R margin key. Code key usually keys have second message are in green, yellow or red. Use code key with the small print on the key to activate that function.... Good luck
Aug 01, 2008 | Swintec 7040 Typewriter
Margin Release for Brother GX-6750 Typewriter
Typewriters have alimit to how far to the right or left that you can set margins. Once you use the alt & 6 key to bypass the current margin setting then move to the new setting then hold the alt key and touch the 7 key to keep it in the new position.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Mar 09, 2007 | Brother GX-6750 Typewriter
Brother EM-530 Typewriter Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
