U-Line BI-95
Problem for U-Line BI-95
Will not get cold
By specialist19 on Aug 12, 2009
Will not get cold. the compressor isrunning all the time and will not make ICE. It has a brand new ice maker unit in it, thermostat, and watervalve from last year.
Solution #1
posted on Aug 13, 2009
Somewhat Helpful)
admiralstopf
Rank: Guru
Rating: 91%, 85 votes
A BI 95 will run until the thermostat is satisfied. The it closes contacts between red and yellow to advance icemaker. Make sure thermostat is set at a warmer temperature. 10-15 degrees is what your looking for in the bucket. After you turn it down and it doesnt cycle then make sure it wires right. Red terminal 1 yellow terminal 2 blue/black terminal3 Or it could be to warm (heavy frost needs defrosting) If everything is running and not cooling then a sealed system is expected. Also make sure you have the right icemaker if not then that could cause everything. Sensor needs to be in the tube about 12 inches.
Was this helpful?
Yes
No
Popular Solutions for U-Line BI-95
Questions and Unsolved Problems for U-Line BI-95
Do you recommend U-Line BI-95?
Answer
Answer
Kenmore Coldspot 106.52703100 The freezer is ok, some frosting, but the refrigerator is not cooling.... (More)
Answer
frezzer gets cold fridge dose not compressor and fan are running fridge only cools to about 46
Answer
My week old fridge is beeping and flashing its lights on and off and the display reads SY CE.
Answer
FRT21HR6AW3 will not cool removed back cover fan running, compressor warm to the touch. frig tries... (More)
Answer
need a new door and gasket. Murray
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For U-Line BI-95:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
