Question about Zenith A27B33W 27" TV
Pip now is on the souce menu whereas cable, video1, and video2 were there before. How do i get rid of pip and return to the former sources?
The Source menu has changed to main, pip, and cable from cable, video1, and video2. Also when the source is cable, the vcr input comes up in the picture-in-picture window. How do I return to the old 3 choices and not have pip on the scene?
  • playtheplay Nov 29, 2007
    I do not have a remote. Can I solve the problem without a remote?
    Sergeant:
    Champion:
  • 298 Answers
Close the pip window first
if your tv/video button on your remote brings up
an input selection menu either press the number
of the ones you want or use the chan^chanv buttons
to select
Posted on Nov 29, 2007
  • Eugene Merritt Nov 29, 2007
    however you been getting into the
    mienu continue to do so
  • Eugene Merritt Nov 30, 2007
    press the tv/video button on the front panel then the menu
    button and go fron there.using chan^ chanv and vol> /If you dont have those buttons then you will need to get
    a universal remote with all the bells and whistles you
    need and a working code for your set hopefully on the list
    with the remote if not do automatic search with the remote if no
    luck there search internet for possible code or
    remote for your particular set
NO PICTURE
Refer to the manual (free download here). Generally, a blue screen indicates a very low or non-existent signal. This can happen when the antenna is unable to gather enough of a signal from a particular broadcaster, or if an A/V input is selected, but the A/V device is not on or providing a signal. Since you are not seeing channel information when tuning, I suspect that the television is set to display an A/V input instead of the internal tuner.
With a working remote, locate the TV/AV button on the lower left (manual page 3 - item 8). When this button is pressed, you can choose to display signals on the ANT, VIDEO1, VIDEO2 or COMPONENT jacks. The ANT selection chooses the input on the RF jack such as an antenna or cable TV (with or without converter box). If using a cable box, the TV tuner should be set to Ch3 or Ch4 as determined by your cable box. Otherwise, select the VIDEO1, VIDEO2 or COMPONENT input that has the source signals you wish to watch from a cable box, DVD player, etc. that is connected to the rear input jacks. Page 7 of the manual details the connection and remote operation.
I hope this helps!
Apr 16, 2012 | Insignia NS- 27" TV27 TV
How do i get ot the aux channel?
Try changes the input on your TV. You will need the TV remote that came with your TV, or a universal remote that has been configured to work with your TV. Find a button on your remote that reads "Source" or "Input". This will cycle through the sources and inputs of your TV including AUX, VIDEO1, VIDEO2, etc.
Jul 01, 2011 | Televison & Video
How do you set up the tv for dvd use? Under the menu the setup options for dvd says N/A.
When you connect a device to a newer model flat panel, it assumes a source input witch in your case it may be video1 video2 hdmi1 hdmi2 or component 1 or 2 and so on. Hit the source button on your remote and toggle it until your reach the input source your are plugged into.
May 29, 2011 | RCA Televison & Video
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    Note:
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    Note:
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Tv has power but no picture. Go to menu set up and auto tuning but scans and advises no channels found. Can you suggest fix, grand kids were fooling around with remote so suspect something simple to fix. ...
you can either try this
- To initialize the adjusted values
1. Press the ADJUST button and then use D / E button to select the RESET option.
2. Press ENTER button and then use F / G button to select Yes.
3. Press ENTER button.
or this
1. Press the MENU button and then use D / E button to select the SETUP menu.
2. Press the G button and then use D / E button to select Main Input.
3. Press the G button and then use D / E button to select the source: DTV, Analog,
Video1, Video2, Component1, Component2, RGB-DTV (or RGB-PC), DVI-DTV
(or DVI-PC).
4. Press EXIT button to return to TV viewing or press MENU button to return to the
previous menu.
hope this helps
John
Jan 04, 2011 | LG DU-37LZ30 37 in. LCD HDTV
I have a rima dv1320p tv/dvd combo. How do I change the channel to the video 1 or video 2 input?
You actually don't change the"channel", you change the source of the image: from the tv to Video1 or Video2. For that al you need to do is to press the Source button on the case of the tv or the button on the remote. The button might also be called TV/AV or Input or have a square with an arrow pointing in it - depending on the version of the remote. The button cycles thru them so just keep pressing till you get the one you need.
Dec 22, 2010 | Televison & Video
I cannot seems to get to the imput channels to play a dvd
on remote should be under video,,or input,,,on front of tv ,,i think input,,,or source,,it will come up 2 video1,,,video2 and so on
Nov 03, 2010 | Emerson EWF2703 27" TV
Can't get componet Video to work
Make sure you have an input Video signal on that Yamaha Reciever (exa. DVD, Cable box, etc...) then choose the right input selection on ur receiver (Video1, Video2, AUX, etc..), then connect ur TV on the receiver Monitor Video out. And put your TV on the right VIDEO input too (Video1, Video2, AUX, etc..). Goodluck
Aug 10, 2007 | Yamaha HTR-5930 Receiver
Panasonic pl sr300
Make sure you choose the right input to record. Example video1, video2, Aux1, Aux2...etc And try to play on that analog input if its going into your monitor. And often if its a copyrighted materials YOU can't copy it.
Aug 06, 2007 | Panasonic SL-PR300 4-Disc CD Changer
Need help with PIP
When you go into the menu to choose the PIP source the PIP comes on to confirm that a valid source has been selected. It is normal for the PIP to close when the menu is exited. To display the PIP normally you will need a remote with a PIP button. Most universal remotes today have PIP functions but if you get a Zenith original replacement then you are guaranteed to enjoy the other PIP features such as size, position, freeze and swap.
Jul 25, 2007 | Zenith Z36X31D TV
Televison & Video Logo
120 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
