Question about Zanussi F1245W Front Load Washer
Wont spin after ive replaced the drain pump
Hi
Ive just replaced the drain pump on my washer.it was an easy job, disconnect the wires, unscrew pump and screw on the new pump and connect up.
Ive had the washer on its side to perform the repair and now the pump works perfectly BUT the machine wont spin, there is no noise coming from the motor.
Any ideas?
  • rafi53 Dec 23, 2007
    My machine washes fine and when it comes to spin, it attempts to start, but blows the fuse instead. When the dial is on spin only cycle, the symptoms are the same. Please help. RS
    President:
  • 1,294 Answers
Plug off the wall. Check to see if all the wires are securely in place, not just with the pump, but all. At the motor un-plug & replug.
Posted on Nov 30, 2007
  • prem mathew Nov 30, 2007
    Hope u cleaned out your outlet filter; the machine will not spin if the filter is clogged.
My washer won't spin and the belt is fine. What do I do?
Hi
One of the most common problems with washing machines, however, is that they won't spin. Usually this is caused by an issue that easily can be fixed, but other times it can be more serious. In some cases, just the balance of the load can cause the machine not to spin.
For that reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Other than lose or worn belt there are various reasons that cause washing machine not to spin.
Check the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in its place.
Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness.
Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
So there are various conditions when a washing machine wont spin. Please check this link to get a detailed idea related to your problem:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | GE WBSR3140DW Top Load Washer
Dacor dishwasher wont drain
You need to determine if the output pump in line with the outlet hose is working and that the outlet pipe is not blocked or obstructed. The pump should spin and just by looking at the pump this can be tdetrmined. With the washer off you could spin the impeler of the pump just to determine that the impeler is free to spin. You could test for power on the 2 terminals of the pump and if present and the pump does not spin this indicates that the pump is "open circuit" and needs to be replaced. "one of the easy jobs on washers"
Mar 21, 2010 | Dacor Epicure EDW24 Built-in Dishwasher
Washing machine will not drain. water wont drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 12, 2009 | LG WM2016C
Water is full in washer and wont drain or anything??
mostly drain problem or spin problem. It won't drain If your washer won't drain, check these:
May 08, 2009 | Washing Machines
Hotpoint aquarius WMA40S Drum wont turn at all
the drive belt needs to be replaced. if you take it to a home depot or a lowes they will replace it at a cheap price. thank you for using fixya
Feb 23, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Miele washing machine wont drain
hi friend,
hoses
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 15, 2008 | Miele W2240 Front Load Washer
Washer wont drain water
Jul 12, 2008 | GE WBSR3140DW Top Load Washer
Indesit.
hi friend,
hoses
Jun 03, 2008 | Indesit W 123 Front Load Washer
Water wont drain
hi friend,
hoses
Mar 27, 2008 | Hoover H140E Front Load Washer
Zanussi F1245W Front Load Washer Logo
63 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
