Question about RCA P52939 52" Rear Projection Television
Lines The tv is in a comercial setting it is on 18 hrs a day seven days a week it started by the bottom of the picture having curves now it has tons of vertical lines in the picture is there any easy fix like a buld or something??
    Novelist:
    Champion:
  • 232 Answers
Are the lines multiple colors? ie; reg, green, blue? If so you need convergence repair, not really something a lay person can do.
Posted on Nov 29, 2007
SOURCE:
Gardenline - garden tap timer.I can't work out the instructions- the timer won't work . Please help and give me an easy guide line to the instructions.
1. Press PROG
2. Press up/down arrows to select the programme you wish to set (16 spaces are available)
3. Press SET
4. Press up/down arrows to set the hour at which watering is to start
5. Press SET to store the hour
6. Press up/down arrows to set the minutes at which watering is to start
7. Press SET to store the minutes
8. Press up/down arrows to set the number of hours over which watering is to take place (0-9)
9. Press SET to store the hours
10. Press up/down arrows to set the number of minutes over which watering is to take place (0-59)
11. Press SET to store the minutes
12. Press up/down arrows to select which days of the week watering is to take place (2nd means every second day, 3rd means every third day). When the required day of week is displayed press SET to store that day. The next day of the week will then be displayed and Set can again be used to store that day. Carry on throughout the seven days of the week as required.
13. Press the clock symbol to store the programme.
Mar 07, 2011 | Hardware & Accessories
TV works fine for 12-18 hrs. Then picture goes off
It seems that your unit has some sort of Thernmal problem or a problem that is shutting down the Power Supply section to the Video side of things.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Mitsubishi VS-6055 60" Rear Projection...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
BlackBerry
Sorry there is no radiation coming from your Blackberry Curve. If so it is so minimal that it will take 200 years. That is if you are on the phone 24 hrs a day 7 days a week.
Good Luck
Oct 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blue curved line at top of screen and yellow curved line at botto
Do you by chance have any speakers sitting on top of the tv or right beside it. Speakers are unshielded and will cause this effect.
Feb 03, 2009 | Televison & Video
Black screen only on new LCD
Sounds like the video board when bad. I would say the TV went defective. Use the 90 day warranty to exchange for a new one.
Always use warranty at this point because the newer TV coming out in these days have very lame warranty.
Rate me, please
Feb 02, 2009 | Televison & Video
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Picture is now a thin horizontal line
now only visible in a thin horizontal line. first of all you reduce brightness to monimum. it just to protect your tv from crt demage. your problem is in horizontal output section as you have mentioned that week or so ago the right and left bottom edges of the picture began to move in like a sideways triangle filled with black so this sympton is due to hor. section problem. your flyback transformer or horizontal output might be defective. but remember check for power supply is ok from surge protector hope this will help.
Oct 07, 2007 | Hitachi 35UX80B 35" TV
Black and white lines
Good afternoon your tv could have some lose solder have a tech look at it.the problem is in the video circuit and related circuit.checkd should be made in the IF circuit.good luck.
Apr 05, 2007 | RCA 27V530T 27" TV
Black screen, small portion of top of picture in view at bottom of screen
your tv has a vertical problem take it to a tech to have them look at it probably on transporting the set to your house it bump around.a look on lose solder could be the problem this could be verified by a tech.good luck.you need the repairman.
Apr 01, 2007 | Sony KP-53HS10 TV
RCA P52939 52" Rear Projection Television Logo
90 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
