Question about Philips GoGear HDD6330 MP3 Player
Phillips GoGear not turning on
I was transferring songs from my new computer which has Vista to my Phillips Go Gear player one night and went to be with it still plugged into my computer. When I woke up in the morning my computer had turned off due to the way I have the power settings configured, but my GoGear was also off. I tried to turn it back on, but it was dead. Anyone have any idea what happened or how I can fix it?
  • manuel_dd May 18, 2009
    I have the same issue. My Philips HDD6330 got hung up and I let it just have the battery run down as I could not remember how to reset it. When I reconnected it to the computer, to charge the battery, it would refuse to go back on. Its turned into a brick! I suspect it needs a minimum battery charged to operate. Any idea how to get it back to working condition? Since the computer can't see the HDD6330, I have no way of charging or using the repair program. Can't reset if it does not come back on. Any ideas?
My Go Gear is not getting on, when i connect it with USB to computer then it starts charging but after charging in a sufficient time period also its not getting on, kindly suggest
Posted on Sep 20, 2012
My philips go gear sa5139 is not turning on. wen attached to the computer it shows that it is repairing but at last it show an unknown error occured and my gogear is still off.the computer is recognising it but in the of mp3 player it is showing nothing.i m charging it with external charger den also nothin happens. plz help me out.
Posted on Apr 18, 2010
  • 8,596 Answers
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
GoGear Media engine error! DRM License using Vista
my phillips gogear mp3 os saying i have no media engine and a drm liecince
Sep 17, 2009 | Philips GOGEAR SA6045 MP3 Player
Phillips Gogear SA5285/37 is frozen
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Mar 08, 2009 | Philips GoGear SA5285/37 Digital Media...
Phillips gp gear will not play music downloaded.
The songs that you transferred have a DRM license on them that does not have transfer rights (i.e.: the songs you downloaded can be played on a computer, but cannot be transferred to an mp3 player). The GoGear is giving you this message in hopes that you will Sync it with Windows Media Player and acquire the said transfer rights.
If you download songs that are in true mp3 format, you will not have this problem. Also, if you choose a music service that allows mp3 transfer at your subscription levwel, and continue to pay for that subscription every month, it will also clear your problem.
-Tha Mp3 Doctor
Feb 21, 2009 | Philips GoGear SA178 MP3 Player
Phillips Go Gear 8G
If you have Vista, you have to go to Philips website and download the updated version of the Device Manager AND you have to update the firmware on the player. If the update stuck for 12 hours, the usual reason is that you were not connected to the internet at the time (although there are other possibilities).
-Tha Mp3 Doctor
Feb 10, 2009 | Philips GoGear SA178 MP3 Player
Lost software disk for Phillips Go gear
www.usasupport.philips.com for missing software - just enter model #
Use Windows Media Player to transfer songs - the programs on the installation CD are not used for transferring - they are only used for repairing the occasional malfucntion
Jun 07, 2008 | Philips GOGEAR SA6045 MP3 Player
Phillips go gear
Install CD is not compatible with Vista - go to www.usasupport.philips.com and enter your model # to get the Vista compatible software
Jun 04, 2008 | Philips GOGEAR SA6045 MP3 Player
Phillips gogear need driver need driver for the mp3 player, it completely stopped working and the philips device manager tries to repair it, but is un successful
To reload drivers:
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Apr 05, 2008 | Philips GoGear SA261 MP3 Player
Phillips 8 GB Go Gear
If you clicked "yes" to an Update for your device, then all your songs have been wiped. Firmware Upgrades and Repairs (whether performed knowingly or unknowingly), will delete all songs from your GoGear.
Alternatively, when you have automatic synchronization set up for Windows Media Player, then re-syncing to the device when the songs don't exist on your computer will also cause the GoGear to be wiped. It's a feature of WMP that I don't like.
-Tha Mp3 Doctor
Dec 25, 2007 | Philips GoGear HDD1830 MP3 Player
Philips Go Gear MP3/Video Player 2 GB (Model SA3125)
The Phillips Go Gear is not compatible to Windows Vista, and there is nothing one can download to make it compatible. I contacted Phillips, and they said that there are no plans to update the software so that it works on Vista. Pass this to everyone that is having a similar problem. Contact Phillips on their website, and request that the Phillips Go Gear software be updated to include Windows Vista. If more people raise a stink (especially threatening never to buy Phillips products), maybe something will be done.
Philips GoGear HDD6330 MP3 Player Logo
1,206 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
