Bosch PB10-CD Radio/CD Boombox
Problem for Bosch PB10-CD Radio/CD Boombox
When radio is plugged in only the gfi outlets work not the radio.
By dday1995 on Aug 12, 2009
when radio is plugged in only the gfi outlets work.. The radio does not turn on nor does the display light work.
Best Solution
posted on Aug 18, 2009
Helpful)
Rtp98
Rank: Apprentice
Rating: 83%, 9 votes
Mines similar, outlets work but radio will only work on battery. Radio will not work on mains only. Charger works at same time so ok. SORTED IT TONIGHT. Inside the charger inside the box there is a fuse (240v 2A) I think, tiny radio fuse. Changed that tonight and radio now works on mains only or battery. Very awkwark job but better than watching a load of cr** on tv. Hope this helps someone.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Bosch PB10-CD Radio/CD Boombox
Questions and Unsolved Problems for Bosch PB10-CD Radio/CD Boombox
Do you recommend Bosch PB10-CD Radio/CD Boombox?
Answer
Answer
do i have to program my new bosch remote to the radio?
Answer
dose not work any more just blows the new fuses when i put them in
Answer
everything is working with the radio except the redio itself any suggestions what might be wrong... (More)
Answer
My PB10-CD power Box was overloaded due to bad ground connection in garage breaker box. The GFCI... (More)
Answer
When the outside temperature is below 60 degrees my Bosch Boombox will not turn on. Once I take it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch PB10-CD Radio/CD Boombox:
Top Boombox Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Boombox Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
