Question about Foxconn P4M9007MB-8RS2H Motherboard
Booting up, I just got a new board, Inserted it, and added a Dual Core Processore with 1 GB ram "rendition"Connected all Components, Turned on and all i got was a black screen., No Boot loader nothing, I checked with 3 monitors still nothing, All connections are in correct, Also after replacing parts and changing different make RAM and Processors the machine make a long loud beep, But still not screen to see any errors, Any help please, Thanks in Advance
    Problem Solver:
  • 15 Answers
Ok the biggest clue you have if you look up on the foxconn beep codes is the long beep which suggests that your ram is faulty , since yoiu have tried so many parts and you got no feed back we can conclued that its your dimm sockets on your motherboard , your motherboard is faulty ......thank you .please return the favour
Posted on Nov 29, 2007
Display off after some time
As you have checked all of the removable components. That only leaves one bit left. The motherboard. Check the capacitors around the CPU socket and the Power connector. There is a common problem with Socket 775 CPU it is that the contacts on the CPU socket can be badly connected even when the CPU is fitted and locked in.
Jul 26, 2013 | Intel Essential DG41WV Desktop Motherboard...
My DG41TX works perfectly with dual core processors, but with core 2 duo not, do 3 beeps and dont show any video, what i must do?? my core 2 duo is E8400 my dual core is E2180 Bios Version:...
The POST beep code - 3 short beeps mean RAM failure.
Try reseating the RAM modules.
If this does not solve your problem then remove all the RAM modules and insert one RAM module at a time into memory slot 0 (1st memory slot) to determine which is the faulty RAM module.
Jul 07, 2011 | Intel DG41TX Motherboard
RAM error
Populating the memory according to the following guidelines resolves this POST error:
  • DIMMs must be configured in identical pairs.
  • The system will not boot properly if multiple DIMMs of varying density or type are installed in the system.
  • The Entry model servers come with a single 512 MB DIMM. If additional DIMMs are to be added to the existing 512MB DIMM, then another 512 MB DIMM has to be added along with the new pair of DIMMs, or it has to be removed when adding the next pair.
  • Valid DIMM pair combinations use slots 1/5 (Bank A), slots 2/6 (Bank B), slots 3/7 (Bank C), and slots 4/8 (Bank D).
  • Up to 16 GB of memory are supported on the Dual-Core 5000, and 5100 series
  • Up to 32 GB of memory are supported on the Dual-Core 5200 series, Quad-Core 5300, and 5400 series
  • FBDIMMs must be installed in pairs unless operating in single-FBDIMM mode. The server supports single-FBDIMM mode only in FBDIMM slot 1A. FBDIMMs must be installed in sequential order, beginning with bank A.
Jan 27, 2010 | HP Compaq ProLiant ML350 G3 Server
I inserted a DDR2 ram and the board stopped working thereafter
According to the manual for this motherboard it supports only DDR2 memory so you won't have done it any good installing DDR ram. Check with the manual that you have the correct DDR2 ram for the board and that you are installing the sticks in the correct slots.
Jun 08, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Intel Dual Core 2.0 GHz Sytem hangs after boot
During your boot screen press the F8 key to boot into safe mode. If that gets you to the desktop run virus/spyware scans. Reply with any results.
Jan 12, 2009 | Bravo Intel Dual Core E2180-2.0GHz 2GB RAM...
Hp system board
the machine uses ddr 1 memory and hold a max of 2 gb of ram
RAM 128/2700 MB DDR SDRAM
Maximum 2 GB (2x1024MB DDR SDRAM)
Sockets Two 184-pin DDR DIMMs
Size 128, 256, 512 and 1024 MB DDR DIMMs
the motherboard is a socket 478 board , the Dual-Core chips are socket 775 so you couldnt use them unless you change the motherboard
Dec 08, 2008 | HP Computers & Internet
Brand new motherboard wont start up
try taking 1 stick of ram off the motherboard, and boot up with 1 stick in slot 1 or 2.
You should get some beeps, 1 is system Ok.
3 is usually RAM/Graphics problems.
Also try booting with the motherboard setup disk in the CD Drive, it may be looking for files to initialise the Board.
And the obvious, check that all cabling is correct from mainboard to front panel. Power on/off Reset et,c.
View the user manual to see if the board has any jumper/dip switch settings for different configurations.
Mike @ compurepair.
Mar 14, 2008 | Computers & Internet
Foxconn P4M9007MB-8RS2H Motherboard Logo
173 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Mark Gough
steyr1
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
