Question about JVC HD-52Z575 52" Rear Projection HDTV-Ready Television
JVC HD-ILA PROJECTION T.V. #HD-52Z575
Our t.v.'s color is off. There is no blue or yellows showing. I have tried to adjust the set according to the book. In the top left hand corner of set where it shows a blimp of red, green and blue, the red and green flash but the blue does not. (this is when I put the "menu" on) What can be done.
We bought the set on 2/08/05 and replaced lamp on 9/09/06
  • 1 more comment
  • riob Dec 11, 2007
    bulb was replaced, since the TV color is way off and seems to be getting worse. Any ideas?
  • Anonymous Mar 29, 2014
    when trying to ajust the color the red and the green colors in the top left hand coner blink
    images on screen in HD and clear, but green. Cycle power on and off, and RGB colors visible but not registered. There are three slightly off images, one red, one green, and one blue. Sometimes, a few power on/off cycles will eventually fix. What could be wrong?
You both will need to have a service center come out to try to reset the TV using the reset jig. A JVC authorized service center will be the only ones that will have access to and training to use this jig. It is a good chance reseting it fix the color problem but it could also be something more serious.
Posted on May 11, 2008
  • C T GILMORE Sep 06, 2013
    AND THAT MORE SERIOUS PROBLEM COULD BE WHAT?
Video downloadhelper 5 button is not showing on my browser for mozilla firefox after downloading
Open Firefox, Click on Open Menu Option in the right hand top corner of the screen, then click on Add-ons in the search box type Video DownloadHelper and click on Install. Once done, you will see and icon in the right hand top corner which is red/yellow/blue color
Mar 14, 2015 | Icon Computers & Internet
The projector is an NEC model VT590 and is connected to my computer for use with a SMARTBoard. In the bottom left hand corner a pink colour is starting to grow inwards. In the upper left hand corner, there...
It is not the smartboard, lamp or the computer as well know, it's the projector itself. This may not work but you at least need to try press the auto adjust button on the projector and then adjust the clock/phase in the menu. If not you will need to send in to NEC it could by the color wheel. Usually they have a warranty for a couple of years.
Jun 05, 2010 | NEC MultiSync VT590 LCD Projector
Yellow arch on bottom left of screen. I have
OK, HERE are the instructions:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Toshiba entry to adjust
With the set on press MUTE on the remote.
Then press and HOLD mute for several seconds and while still holding it on the remote press Menu on the front of the set.
A (S) should appear in the upper right corner of the screen. (It means you are in the Service mode)
Press menu again on the front of the set
7 on the remote will call up the convergence grid
3 on the remote will change the color to adjust from red to green to blue(do not adjust GREEN)
You navigate the grid with 2, 4, 6, and 8 buttons.
To stop the cursor from blinking so you can adjust at any point use the 5 button—to move again use the 5 button.
When you finish you exit by hitting 7 on the remote again.
Sometimes you have to try a few times to get into the menu—I have had my problems but once in it is easy.
if adjusting does not cure the problem one of the convergence chips this set uses and or a resistor are bad.
Let me know what happens and if you need more help let me know
SD TECH
Sep 30, 2009 | Toshiba TP50H50 50" Rear Projection...
Hp psc 750 won't print in black
ok, need a bit more info but when you select to print document, in the print options screen that comes up make sure your printer is selected in the top left hand corner, select preferences, then select color, click on advanced color settings and make sure all the colors are set to zero on the left hand side, to adjust the figures to zero use the sliders in the center, then select ok, tick the box besides print in greyscale and select ok, this should print your document in black ok, hope this helps, get back to me if still having trouble, cheers, Brett.
Jun 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Im trying to calibrate my printer but it wont print black what do i do
The calibration sheet is comprised of many different colors - cyan, magenta, yellow, and black. Just because you are missing black ink doesn't mean that you can't do the calibration. As long as there is a blue arrow in the top left hand corner, you can match that up with the yellow arrow on your scanner, press the start button, and the printer will calibrate.
Nov 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Hitachi 53SBX10B
It sounds like the lamp is failing.
Jan 06, 2018 | Televison & Video
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
Blue Convergence just went out?
High Voltage Capacitor? Leave the set unplugged for 1/2 hour most components will selfdischarge, as for your problem, being a Magnavox, you have one of two problems, the convergence I suspect is what is blown out, this unit probably uses STK392-110 Ic's, I would suggest replacing with STK394-160e chips as they are probably shorted, some of the big resistors (1 or 2) may be opened up also, usually they change color. The only other thing that would cause usually a yellow color in the corners is the CRT Fluid, it changes from clear to Orange in color and clamps off the blue color from the fringes, I suspect the chips need replacement, dont forget to put some heatsink dope behind them, they are usually on the left in the front of the set (from the back) Big long heatsink that is fairly tall (probably the biggest heatsink in the set.) Good luck, and the repair usually runs around $350.
Jul 13, 2007 | Philips Magnavox 51MP392H Rear Projection...
Blue/Yellow in upper left corner
I have the same problem and now there is convergence problem with the entire screen, double images and ghosting ...i was told that some IC's are burned our ...etc..i'm waiting to see if they sell the entire board since the TV's are 10 years old... will let U know what i get as a response.
Jun 05, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
416 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
