Question about Canon ImageRUNNER 330s Copier
Dark Printouts I believe that the image drum may be causing the dark printouts, please confirm this and if possible supply a replacement part number? If there may be another part that causes the issue please do not hesitate to let me know. I already removed the charge wire, cleaned it along with refill of toner and vacumed all of the paper path areas and still have no results.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Try adjusting to light is there any change? what about photo mode?
try this site for the drum
http://www.precisionroller.com/
Posted on Dec 12, 2007
SOURCE:
Konica Minolta bizhub c550/c650 give bad image printouts
run gradation pattern procedure
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 22, 2017 | Konica Minolta bizhub Office Equipment &...
My printouts have a very dark haze over them.......the printed letter are fine but it looks like the print cartrige is dumping ink on my paper as it prints. It look like a bad fax copy. What is the...
Either you purchased a a bad quality remanufactured toner cartridge or your fuser film is damaged.
If there is some kind of debris in black color that is on printouts, your fuser film might be damaged. Have a printer technician replace it.
If there is no debris, only bad quality printouts, it's the toner cartridge that needs replacement.
May 31, 2010 | Brother HL-2040 Laser Printer
All printouts have a 3/8 inch wide light vertical line -
Try an old toner cartridge if you have one. Does it do it when you use the copier function. Steven 805-520-3003
May 12, 2010 | Brother MFC 9700 All-In-One Laser Printer
The printer is printing dark vertical line on the
90% or more of the time on this printer dark lines are coming from your toner/drum cartridge. You can verify this by changing cartridges if you have a spare. If you don't then remove the cartridge and look at the colored cylinder in the cartridge and see if the same "lines" are on the cylinder that are on your prints. This will tell you for sure that the cartridge is bad.
Dec 13, 2009 | Samsung ML2250 Laser Printer
Printer is making 2" dark streeks down center of printouts
Check your toner drum for scratches. If none, replace your fuser.
Oct 07, 2009 | Dell 3100cn Laser Printer
Laser jet produces printouts that are smudged and dark
Remove the toner cartridge and use a soft cloth to wipe the photo drum clean of toner. Put it back and try again, if you still get bad prints, then you need a new toner cartridge.
Apr 01, 2009 | HP LaserJet 1200 Printer
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
Ink gets carried over to subsequent sheets
More than likely your maintenance kit roller has been impacted with ink and is not applying enough lubricant to the drum. You can replace the maintenance kit and run cleaning procedures a couple of times to allow it to clean up.
Now the other issue is if you are using a third party ink stick. By that I mean non xerox brand ink sticks. I have seen those cause that problem more often than not.
Pull out the maintenance kit and see if the large roller, which should be a off white, is black.
Exacly what is happening is your maintenance kit puts a very thin film of silicon oil on the drum so that the ink does not adhere to the drum more than normal. When that roller becomes blackened, it isn't very effective and you get some of that residual imaging.
Oct 09, 2008 | Xerox Phaser 8400 Laser Printer
Canon 330s Copier with Dark printouts
How dark is it??
canon is sensitive to dust,
turn off machicne take off top copy glass move scanning glass and wipe with a clean towel.
try adjusting the dark and light does it change? if it comes out better on light then the drum is the problem. ( getting old)
Nov 29, 2007 | Canon imageRUNNER 400S Copier
64 people viewed this question
Clive
Clive
old marine
old marine
Ekse
