Question about Perlick FR24 Stainless Steel
Perlick fr24 my perlick fr24 is making a a loud noise from the motor
0 characters
1 Points
Freezer temp is below zero it is minus 2.00 will not adjust.
Negative 2 degrees is a good temperature for freezers, but if you want it warmer, raise the thermostat up (warmer temp) In the refrigerator section, & open damper (or set the adjuster knob in the back of the freezer to warmer). If the motor is making a loud noise, it may be hitting ice built up from the evaporator...thaw out.
Feb 28, 2015 | Refrigerators
Loud noise, not ice maker
There are two large motors in those. 1 is the fan and the other is the compressor. There is nothing that you can do about the compressor but the fan can get noisy if there is an ice build up from the coils not defrosting right.
Dec 30, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
Sep 16, 2013 | Refrigerators
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool top-freezer refrigerator makes loud noise
Do you think it is the fan in the freezer or could it be the water valve when the icemaker is filling?
Nov 27, 2012 | Refrigerators
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
Making loud noise, sounds like the fan is off balance when the compressor turns on but could this be a faulty motor instead?
It could be a motor. Make sure the blades are not hitting the shroud. Normally the motor stops working when it goes bad. I have not found one making a noise so loud it was noticeable.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
May 27, 2009 | Samsung RS2630SH Side by Side Refrigerator
LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
Perlick FR24 Stainless Steel Logo
41 people viewed this question
Top Perlick Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Perlick Refrigerator Expert? Answer questions, earn points and help others
